SL/R231: How to trickle charge 2013 SL 550
1 Post
2013 Mercedes SL550
just purchased a 2013 SL 550 need help in finding a way to set up a trickle charge for when it’s laid up for six months. Regards, John
shows the removal of windscreen on A217. I guess between the two videos I can figure it out. However I am hoping that that small , what appears to be a button type clip is inside the bottom of car somewhere , I lost it when I first discovered the screen pulling away. No rips in screen though
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_4027_0f969a5c6c599835ce5ef8ae47acac4c23dd36fe.jpg)
https://smartercharger.ca/
There is much debate about whether the small ECO start-stop battery behind the passenger seat will charge from the posts under the hood.
My experience—I’ve taken voltage measurements during trickle charging—is that the ECO battery did not take a charge from the posts under the hood; however, my ECO battery was almost fully charged at the time. There is speculation, however, that the ECO battery will accept a charge from the posts if it falls below a set threshold.
Here is a link with more info for your consideration:
https://mbworld.org/forums/sl-class-...ml#post8326443
The following 2 users liked this post by hornethandler:
crconsulting (12-19-2022),
rorywquin (12-19-2022)
After deciding where to mount the trickle charge what method is best balance of a clean install that don't get in the way or get tangled in moving parts?
Likewise at risk of being a complete dork what mind tricks are used to help prevent attempting to drive off with the charger still connected? Maybe I'll go as crude and obvious as having the power cord run under the car and loop on the ground by the driver's door then up to the plug on the wall.
No, NO NO! Won't mount the charger inside for heat issues and desire to potentially use the charger on another vehicle.
Montreal300 (01-23-2023)
