SL/R231: Rear Window Cleaner
The 231's inside rear window is indeed 'a bear' to clean, so this should make it much easier.
You can order the Griot's Garage Set (shown) or just a window cleaning tool through Amazon!
https://www.monzacarcare.com/shop/wa...FdiF1Qoda5EJVA
I would personally worry that repeated mid-cycle 'interruptions' might cause some kind of problem with roof operation, given all the micro-switches, actuators, and motors that are involved in with the opening and closing process.....
So...Thanks for the additional suggestion, but I think I'll just stick with the long handle 'cleaning brush' method whenever the inside rear glass of my 231 needs some attention!...
I open the SL roof halfway to clean the rear window but it can and does fall into the boot / go forward under it's own weight. Clearly a risk of injury if it goes backward. I'm looking into making a pole to keep the roof propped open (so weight biased toward the front) as theSL glass roof is also very heavy compared to the SLK roof.
