SL/R231: AutoTalent | Renntech Performance Ecu+Exhaust+Suspension For Mercedes-benz SL63 Amg
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
Click HERE to order Performance Ecu+!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. The RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicles entire power band. By modifying ignition timing and throttle mapping, optimizing air/ fuel ratios, increasing the engines rev limiter and modifying boost mapping for turbo charged vehicles, RennTech performance software unleashes your Mercedes true potential. RennTech intermediate level ECU upgrade for the Mercedes M157 engine still offers huge gains in performance across the entire RPM range, but with a slightly reduced peak HP and torque from our standard tune. This is ideal for customers who want increased performance in their daily driver without worry of extra strain on driveline components or for areas and countries with extreme altitudes, temperatures or fuel quality concerns.
Features
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Renntech Exhaust Stainless Steel Muffler
Click HERE to order Performance SS Muffler!
RennTech stainless steel (SS) sport mufflers are hand made and rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech mufflers offer incredible sound in a lighter than the stock weight exhaust with improved performance. This is accomplished by reducing exhaust system back pressure and improving exhaust gas flow.
Features
Reducing exhaust system back pressure
Lighter than the stock weight exhaust
Stainless steel (SS) sport mufflers
Mufflers offer incredible sound
Long-lasting anD reliability
Gains: up to 10 HP & 15 TQ
Improved performance
Deliver a deep sound
Renntech Performance Diverter Valve
Click HERE to order Performance Diverter Valve!
RennTech 3rd Generation Diverter Valve for the M157 5.5L V8 BiTurbo features an all-new Blow-Off Valve implemented into the re-designed OEM turbo tubes. The Diverter Valve releases the boost in high-boost situation and/or boost spikes. This especially helps during the shifting process, for faster shifting and a quicker boost response for the next gear. It helps to eliminated the so called 'Boost Lag'. With the installation of the RennTech Diverter Valve, they are able to supply the engine with more boost pressure in order to gain higher HP numbers. The turbo tubes are ceramic coated in titanium to sustain high temperature and provide a more aesthetic look in the engine bay
Features
Helps to eliminated the so called 'Boost Lag
Helps during the shifting process
Improves vehicles responsiveness
Increased engine performance
High quality material used
A quicker boost response
Higher Horsepower
Faster shifting
Renntech V3 Digital Suspension Lowering Module
Click HERE to order Performance Suspension Lowering Module!
The RennTech V3 Digital Lowering Module (DLM) is designed to work with all available Mercedes Airmatic or ABC (Hydraulic) Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The DLM requires no splicing or soldering to the factory wiring harness. The RennTech harness utilizes the factory pins as to allow a completely reversible installation. The unit also supports speed-dependant lowering that allows the vehicle to return to its factory ride-height at a pre-set speed. This removes the need for the vehicle to be aligned after lowering. The user can maintain the factory longevity and still have the lowered look at low speeds. All RennTech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features
Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 53mm x 73mm x 24mm
Weight: 1.2oz
Renntech Locking Limited Slip Differential
Click HERE to order Performance LSD!
RennTech Locking Limited Slip Differential, a differential is the last point between the engine and the wheels where power is transferred. The differential functions as a system to direct engine power at the wheels while allowing them to rotate at different speeds. By upgrading the differential, you benefit in both straight line stability and vehicle handling while cornering. During a full power straight line run, our LSD (limited slip differential) will lock 100% and provide torque equally to each powered wheel, providing stable straight line runs. When exiting from a corner, our LSD's transition to the full 100% lock position is smooth and predictable. This gives the vehicle better traction and stability throughout the corner, improving overall lap times and a noticeable improvement in overall vehicle handling. The track is not the only place where the differential comes into play though. Bad weather and harsh road conditions can make the street a dangerous place. In snow, ice, wet weather and regions where the road surface can become unstable, our LSD easily adapts and adjusts tire rotation to increase vehicle stability on the road and help to dramatically improve driver safety. RennTech differential is a unique, patented, clutch- type LSD which makes this a true100% locking differential. Because of this function, there is no movement of internal parts, leading to less heat being generated while in operation and in turn, less wear of the friction disks.
Features
A noticeable improvement in overall vehicle handling
Provide torque equally to each powered wheel
Provide stable straight line runs
Gives the vehicle better traction
Stability throughout the corner
Improving overall lap times
Provide straight line stability
Increase vehicle stability on the road
Help to dramatically improve driver safety
Renntech Performance Toe Link Kit
Click HERE to order Performance TLK!
Adding a RennTech toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics without negatively impacting ride quality and comfort
Features
Improved vehicle handling characteristics
Maintains stability at high speed
Provide ride quality and comfort
Improve performance
Stunning good looks
Design is perfect
Simple to install
Renntech Performance Package
Click HERE to order R1 Performance Package!
Click HERE to order R2 Performance Package!
Click HERE to order R3 Performance Package!
The RennTech R1 Performance Package is the perfect entry level performance upgrade for the E 63 AMG. With the combination of the RennTech ECU Upgrade and the latest, 3rd generation Diverter Valve RennTech is able to add up to 91 HP and 132 LB-FT to the 5.5L V8 BiTurbo engine (compared to RennTech rated stock performance). The addition of the upgraded diverter valve helps the engine to handle boost spikes in high boost pressure applications better. A surplus of boost will be released to the atmosphere and the turbocharger can be supplied with air quicker after the shifting process. This helps to eliminate the 'Turbo Lag'. The R1, R2, R3 performance package increases performance to 696 hp and 801 lb/ft at the crank, without sacrificing daily driver comfort or reliability and offer huge gains across the entire RPM range. Due to increased power and boost levels, 93 Octane or higher gasoline has to be used with R1 upgraded RennTech vehicles to avoid damage to the engine. States known for poor fuel quality have to be supplied with a lower power setup. Please call for details and Race Fuel options.
Features
RennTech 3rd Gen. Diverter Valve
BMC High-Flow Air Filters
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Seven speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improved shift response
Greater drivability
Shift timing
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
