SL/R231: Front License Bracket Removal...
Old Feb 18, 2020 | 05:46 PM
Dr. Manhattan's Avatar
'17 SL450, '25 Lyriq, '25 Sonata Hybrid, '96 Corvette GS coupe
Could someone tell me whether or not there would be visible holes in the front facia of a facelift SL if the factory-supplied license bracket was removed? I'm seeing cars in my search that have front brackets mounted, and if I find one of these with ABC, I'll be wanting to allow for potential body work if it will be necessary.
Old Feb 18, 2020 | 06:27 PM
WN1X's Avatar
2013 SL550, 2017 GLE350, 2018 Audi Q3
I was fortunate my 2013 SL550 never had the front plate mount installed. I've got it in the original MB bag collecting dust in my garage.
Old Feb 18, 2020 | 06:44 PM
Honestly, only an hour later and I just got a tip on another thread of a 450 at an out of state dealership that has a front plate bracket installed! Now I really have to know if I should avoid the front bracket or not...
Old Feb 18, 2020 | 07:52 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Am I reading your posts correctly? You are making a decision to buy or not buy a potential 100k automobile based off whether the front plate bracket is installed or not installed?
Old Feb 18, 2020 | 07:53 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Bob, ask the dealer!! If folks are right about the difficulty in reselling these cars with that expensive option you may have some wiggle room, price-wise. Heck, even if they simply BELIEVE that canard (which evidently most dealers do) that may give you some leverage!
Old Feb 19, 2020 | 01:45 AM
LOL...not really. The question about hole visibility was on the up and up. The rest was kind of tongue in cheek, but something to keep in mind if going forward. The car also has my least favorite wheel option, but that's even more easily remedied than holes in the facia.
This may be a good point. I've often wondered if the presence of ABC would make an SL harder or easier to sell. I'm sure the dealers would like to have it both ways...first they tell you to avoid ABC like the plague when buying new, and then when selling the car used they have the gall to tout the ABC option and ask more for the car? I don't know if this is the case here, though. The ask on this one isn't too far out of line with that of non-ABC cars. I'm sure they knew the answer to this before purchasing the car.
Old Feb 19, 2020 | 10:04 AM
Wolfman's Avatar
Super Moderator
Wish I could help on the facelifted SL as I never bothered to install the license plate.
On the original 2013 model the plate holder is screwed into the bumper leaving two holes.
That has been normal business with Mercedes as well so my money is on holes in the bumper.
That said, it will cost a few hundred with a body shop to fix this or a couple of bucks to plug the holes (not invisible).
Old Feb 19, 2020 | 09:05 PM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
My CPO SL550 had a front license plate bracket, which I removed. I went to Home Depot, found two flat end rubber plugs the same size as the holes, plugged them in, used touch up paint and you literally cannot tell they are there. The holes are not that big, at least mine were not.
Old Feb 22, 2020 | 07:21 PM
This sounds like a viable solution...
Old Jul 3, 2020 | 09:51 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
I asked the dealer to remove the bracket and fix the holes as part of the purchase deal. The idiots who installed the bracket used what were basically long wood screws and so it not only had two holes in the bumper from that but also scrapes on the top of the bumper from the upper plate screws being too long. Their body shop did the fix. It turned out OK.
Old Jul 3, 2020 | 09:58 AM
.LMS.'s Avatar
2016 SL400
Yea - do this. When I bought my Volvo I told them not to mount a front bracket and when I came to take delivery, there it was in all it's splendor on my front bumper. I told them I am not taking the car - they need to fix that first. And they did with no debate, so it's gotta be cheap. It's not that much of a job for a body shop to do this.
My SL has the holes and I can see them there but it hasn't been a big deal for me (and I'm surprised by that). I probably should get them filled next time I get a doll up job.
Old Jul 5, 2020 | 10:14 PM
RobertF's Avatar
2017 SL550
FWIW We just purchased a 2017 550 SL from North Carolina where they do not require a front license plate. Unfortunately, here in Virginia they are required. The original owner still had the factory bracket in the trunk but I was reluctant to drill the bumper. Eventually, I used a no drill front mount from Sly Brackets. Before I found these folks I was looking for how I could plug the holes in the bumper if I used the factory supplied bracket and later wanted to sell the car.
I found a company called Bumper Plugs that will sell you a set of two plugs for this purpose painted to match your cars factory color for $29.95.
Old Jul 5, 2020 | 10:22 PM
.LMS.'s Avatar
2016 SL400
Weelllll, I also live in a state that requires front plates. But starting in around 2014 when I bought a car that just didn't look right with a front plate, I have been leaving them off. I have never been ticketed, 4 cars later (hopefully I didn't just jinx myself). I figure if I get pulled over I'll just respectfully say "Officer, if this was your car would you put a front plate on it?". If that doesn't do it I'll pay the fix-it ticket. Maybe my state is more forgiving than others, but I'd be surprised it's a royal pain for a lot of other things...
Old Jul 6, 2020 | 05:27 PM
Thanks for the great tip for all us **** folks who hate front plates!
I should say that I finally purchased my SL a little over a month ago from a dealership in TN. The car was local to the dealer and TN does not require front plates, so the car is clean in the front. My original home state of WI does do front plates, but like .LMS., I haven't mounted front plates on any of my cars there in decades and haven't had a problem. The SL is being registered in GA, where they don't do the fronts either, so I'm home free. As my wife is fond of saying, "all that worry, for nothing"...
Old Jul 6, 2020 | 05:44 PM
Originally Posted by .LMS.
Yea - do this. When I bought my Volvo I told them not to mount a front bracket and when I came to take delivery, there it was in all it's splendor on my front bumper...
I went through the same thing when my then-new 2011 Golf TDI arrived at the dealer. I had gone through the whole "no front bracket" conversation with the sales person...twice. I was there when they pulled it off of the delivery truck (without a front bracket). I went home and came back the next day to take delivery, and viola...there it was. And not only did some boob install it, but whoever it was decided to "eyeball it", and it ended up over two inches off-center!
Old Jul 6, 2020 | 09:52 PM
.LMS.'s Avatar
2016 SL400
... As my wife is fond of saying, "all that worry, for nothing"...
Gawd they love to say that don't they...
Old Jul 7, 2020 | 02:37 PM
LOL...oh yeah. She was very good about the whole SL search/acquisition process, though.
