SL/R231: 2013 SL550 - goes into limp mode when I punch it
Old Sep 14, 2023 | 08:38 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by Sn@kedriver
Amazon's Choice...don't judge me.
ANCEL AD310 Classic Enhanced Universal OBD II Scanner Car Engine Fault Code Reader CAN Diagnostic Scan Tool-Black
I kinda do have to judge. Universal means generic. I know it was inexpensive, but it is NOT going to provide the features you will need for your car. If you are going to drive a $100k car (originally), you can't go cheap on essential parts or tools if you are going to do this stuff yourself.
Generic scanners are OK to check your car before it gets smog tested or to clear generic codes, but OBD only specifies that manufacturers provide very basic compatibility while most manufacturers then use proprietary codes for their specific control modules. Do yourself a favor and get a scanner specific to Mercedes cars. Pick one of these.
2023 LAUNCH X431 Fit for Benz Sprinter Full System OBD2 Scanner, Bi-Directional Diagnostic Scan Tool 2023 LAUNCH X431 Fit for Benz Sprinter Full System OBD2 Scanner, Bi-Directional Diagnostic Scan Tool
FOXWELL NT510 Elite fit for Mercedes Benz Sprinter OBD2 Diagnostic Tool FOXWELL NT510 Elite fit for Mercedes Benz Sprinter OBD2 Diagnostic Tool
iCarsoft MB V3.0 for Mercedes-Benz/Sprinter/Smart Diagnostic Tool iCarsoft MB V3.0 for Mercedes-Benz/Sprinter/Smart Diagnostic Tool
Old Sep 14, 2023 | 09:49 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Had the wheel sensor replaced and it cleared the Christmas tree of ABS and antiskid and drives fine. No engine light either. Gave my bro $200 since he ordered an OEM sensor and I didn't lift anything but my wallet. I bet this would have been a minimum $500 dealer charge. Or a $50 maintenance charge and a $450 car wash.
Any chance you took photos? I am curious to know where the wheel sensors are located and what they look like. Is there one at each wheel?
Old Sep 14, 2023 | 12:58 PM
JettaRed's Avatar
Veteran: Army
Old Sep 14, 2023 | 01:06 PM
JettaRed's Avatar
Veteran: Army
Old Sep 14, 2023 | 01:07 PM
JettaRed's Avatar
Veteran: Army
And there are more. Just search Mercedes Wheel Speed Sensor on YouTube.
Old Sep 18, 2023 | 03:38 PM
toi's Avatar
toi
2014 sl550
Originally Posted by Swiffty
I had the same issues with my 2010 E350 , punching it and limp mode every time, I never took it to a dealer or mechanic because they will not know that your accelerator pedal sensor is going bad, so they will charge you for something and it will not fix the problem. So I changed the accelerator pedal entirely, and no more problems! I suggest once you get your new pedal, reset the transmission to learn your new pedal properly. Swiffty
i was going to suggest replacing the pedal also
Old Oct 7, 2024 | 12:01 PM
  #32
Sn@kedriver's Avatar
2013 SL550
Wheel Speed Sensor ... again
I'm still figuring this thing out and can't seem to Erase the codes, but the Engine light is out and no Cautions or Warnings displayed. Under the menu item that says "Stored Codes", it has:
C0034 Right Front Wheel Speed Sensor
P061A Internal Control Module Torque Performance
I think I read somewhere how the Speed Sensor failure can confuse the crap out of the sensor systems and cause mismatches that latch this type of generic code. The only issue I had was an inability to Erase the codes regardless of key state. Further investigation here, but seems all is well now and only $200 to a good man.
Hey Gents! Looks like it flopped sides and the other sensor went out, so apparently the life expectancy of these is around 10 years. Question: does anyone know if you can overrride the limp mode? Since I know this is nothing but a sensor issue, I would like to drive the rig the 2 miles to my mechanic's shop without calling a tow truck. Since I moved to a high rise, I just don't have the tools on hand for a job like this, simple as it is and experienced as I am with this kind of basic repair. Thanks.
Old Apr 30, 2026 | 05:09 PM
  #33
DocHoliday77's Avatar
SL550 R321
I paid $960 for parts and labor at a Mercedes-Benz dealer in Florida. This happened on the same day I bought my SL, and I was furious! However, when those sensors go bad, they can throw all sorts of error codes, making you feel like the car is falling apart. After I changed the sensors, I drove it for 1,000 miles without any issues.
Old Apr 30, 2026 | 05:11 PM
  #34
SL550 R321
You can disconnect both batteries, touch the terminals, wait 15 minutes, and then try again. I've towed mine. Lessons learned: always change in pais. I fought my dealer for just one, and she smartly said, "If I do one, you will be back here for the other soon." Might as well do both.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
