SL/R231: Noise From Roof
I have a 2015 SL 550, 20,00 miles. I am getting an annoying noise coming from the upper right retractable roof (assuming in the mechanism). When the top is down, I do not have the noise, only when traveling. I took it to the body shop and they could not determine where the sound was originating from.
Any one else have this issue? If so, what was the fix?
Thank you,
JD
Also do a search for vario roof noises and you will find info describing how to treat the rubber seals on the various sections of the top components. My car is a 2018 with 14K miles; I just did the "KRYTOX" treatment and plan to do it every yr or two to keep the rubber supple and prevent noises that develop when the rubber gets hardened or dirty.
Word of caution.....I'd only use the MB recommended Krytox not anything else (big difference in results....over the counter products leave sticky residue and can gum up the drains (in some cases pretty small passages) and then the drains will back up and flood out the trunk ect.
So....bottom line: Do the search, buy the Krytox (I can't recall now but, I bought it from eBay or Amazon for less than from MB but, read up, use the right stuff and I'd wager the issue you have will be fixed and your seals will thank you
The noise is the typical slight rattle/low volume ticking/knocking only when I am driving. I am not sure if it is the rubber seals. The vehicle has always been in the garage in good climate. What exactly does the Krytox accomplish or what is it?
Thanks Steve!
Joe
Thank you,
JD
Yup that is the general ide per the VW video but, you don't need a special cleaning tool as just a clean lint free (lint free important as it won't make a mess AND won't get FUD into the drain tubes that are part of the rubber seals0
Just get the roof in the 1/2 opened position (make sure it stys there/ maybe use a prop stick ect as some searches will show you) .....wipe out the rubbers and channels water or little alcohol ..then apply the Krytox (only Krytox)....do not run it in like the VW gus shows...a little goes a long way !
I put a small thin line along the rubbers and then work in with my fingers all around until it is absorbed into the rubber. (works great and does NOT leave a residue like lots of aftermarket products do
I did roof, trunk, under hood and door seals and used less than 1/2 of the small bottle so it goes a long way.
As far as the noise you hear: Seals can make funny noises so could be the rubber seals but, also the latching mechanism is in the 1'st roof panel at the front (open your roof and take a look...you will see the clamping mech (a solenoid motor pulls a lever rod and the L & R clamps in the roof section seize around the roller pins in the windshield header.........so what you hear could be the mech in the front of the vario roof panel.
Hope the above is some help.
Thank you for taking the time to give me your detailed suggestion(s). I will order the Krytox now and perform the above and see what happens!
Thanks again Steve,
Joe
Which Krytox? there are several available and the pricing is all over the board.
Both Ebay and Amazon.
Thanks,
Joe
My guess is something is loose, or two pieces of metal tapping one another as you hit any slight bump in the road.
I am going to try the Krytox which was suggested above, just doing the best I can.
Thanks again!
Joe
Yes I did check that. The right rear was actually low on air, filled, no change.
Thank you,
Joe
