SL/R231: Unlucky morning - hit a black cat. Need advice.
I was driving this morning and a black cat ran out in front of my SL550. I heard the thump as I hit him, there was not time to do anything. Not a great way to start the day. About ten minutes later a guy pulled up beside me and said, "Do you know you have a black cat stuck to your grill?" Sure enough, the cat's head had gone through the lower grill and his legs were splayed on the front of the car. I had to pull over and dislodge the cat. He broke the lower plastic grill, which seems to have affected the "safe distance" assist function. I cannot disable it.
I can live without that but I have a couple of questions. First, where is the best place to buy a replacement grill and can I replace it myself. Second, any idea of the cost to get everything up and running again?
Thanks for any input or guidance...
2020 GLC300 -2013 Sl550 - 1997 SL600
You should be able to swap that yourself. Sounds like you may have some debris in there or may have damaged the front sensor since you’re getting a Distronic error. Inspect carefully, it may have damaged some wiring.
Nah, he’s good, the black cat didn’t actually CROSS his path, it was a little short
Lower grille, non AMG part number: 231-885-31-23. $58.96 at mboemparts.com (assuming your talking about lower grille)
Nah, he’s good, the black cat didn’t actually CROSS his path, it was a little short![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
When you say “ grille” I’m assuming the lower grille in front of the oil cooler. Since it was a cat, I’m also assuming it was low to the ground.
If it’s the upper grille (where the star is). That’s a different part number. Also your Distronic sensor is behind that MB star. If that’s the case, you’ll want to inspect & clean that area.
upper grille PN # 231-888-02-60 (if you don’t have night vision)
Good Luck!
Good Luck!
