SL/R231: 2015 Sl400 tapping/ knocking at cold only startup.
Old Aug 30, 2021 | 01:01 PM
ThatsMyDawg's Avatar
SL 400
Yes, that is my car. I remembered I could post a video to YouTube and then show that ink here..I have just posed a screenshot of the invoice that went with that work. The other invoices I have are for the other work and not relevant.
Originally Posted by crconsulting
Is that your car?
That sounds like tensioners. But if they did them properly that “should” have gone away.
Take a look at your invoice did they do the check valves along with tensioners?
There should be part numbers on that invoice.
What are they?
Do you see a 2780503300 or similar?
Old Aug 30, 2021 | 01:03 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Having just done my tensioners and check valves myself, I confirm the sound goes away immediately if both lobes were done. There is no wrong way to install these parts, imo.
Old Aug 30, 2021 | 01:49 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
I don’t see check valves on that invoice.
Yes I agree. But as long as ALL recommended parts were installed and none were defective (rare but always a chance)
I don’t see check valves on his invoice…
There should also be a choice of two different size check valve sizes, see the Service Bulletin:
https://mbworld.org/forums/attachmen...6435_ver_3.pdf
Old Aug 30, 2021 | 01:53 PM
SL 400
They are not on there and I do not know why MB didn’t replace them. I guess that is a question for me to ask them.
Old Aug 31, 2021 | 01:41 AM
SL 400
If I have found my correct engine# and searched properly then it looks like my engine is not part of the notice for repairs, although it makes the exact sound they describe in the repairs list. I may be just tired and reading the info wrong. (2:17am and I am up searching)
My engine # is 276825 30 130705 (I think)
Old Aug 31, 2021 | 06:12 AM
Baltistyle's Avatar
My engine was not in the “official” range either. Needed them anyway, verified by opening up.
Old Aug 31, 2021 | 07:19 AM
  #32
SL 400
I understand. I meant so I could get it fixed for free. How would I prove/confirm MB checked the valves but they didn’t need replacing? It’s not noted on any paperwork.
Old Aug 31, 2021 | 09:12 PM
  #33
Check valves are an integral part of the repair. You can’t do a full repair without replacing the check valves. They have different spring pressures which help keep oil pressure to tensioners so they function properly when cold.
There is no “testing”. Just replacement.
The repair should be two parts as described in the Service Bulletin.
Many people on mbworld have done the job, here’s a brief view.
https://mbworld.org/forums/e-class-c...-rattle-3.html
Here’s what a proper kit should look like. (There are two different size bores, so you need both size check valves unless you’ve pre measured them.
https://www.fcpeuro.com/products/mer...SABEgLFaPD_BwE
Old Aug 31, 2021 | 10:54 PM
  #34
Baltistyle's Avatar
A little clarity.
there is upgrading of tensioners in cars that already had check valves installed.
there is installation of check valves in one or both sides in cars that did not have them from the factory along with new tensioners as well.
meaning a car repair sheet/ invoice does not necessarily have to include the check valves as they may have been in there making the tech think only tensioners need it. I do not imagine the valves themselves ever needing replacing. It’s a Schrader valve
Old Aug 31, 2021 | 11:01 PM
  #35
Ever push down on a shader valve? It has a spring. That check valve is a superseded part number. Yes, some early engines did not come with those valves at all. But even if the engine has check valves they should be replaced.
The TSB is quite clear even if it has the valves they should be replaced to the new check valves. The newer engines within the affected range that already have the upgraded tensioners, and have the older check valves installed, Mercedes only recommends replacement of the older check valve and not replacing the tensioners. Those check valves are pretty important piece of that procedure.
There’s a tool to remove and replace the check valves. $20 in parts & a few minutes to rule out oil pressure issues to tensioners vs having to rip it apart again is cheap insurance.
“Engine 2769:
1) Up to engine number 276 9xx 30 365996 install check valves and chain tensioners
2) From engine number 276 9xx 30 365997 up to engine number 276 9xx 30 406603 (February 2013) install check valves only (optimized tensioners installed in this production range) “
Old Sep 1, 2021 | 01:41 AM
  #36
SL 400
Good info. My engine # is 276825 30 130705
“Engine 2769:
Old Sep 1, 2021 | 12:46 PM
  #37
chassis's Avatar
2017 GLE350 4MATIC
@ThatsMyDawg have you concluded that your engine needs check valves and tensioners?
Old Sep 1, 2021 | 01:02 PM
  #38
SL 400
I have not made any conclusions thus far. Everything is speculation, because I haven’t had time to have my car towed from MB to my indi yet. I have been tied up on a business project.
My service adviser returned my call yesterday, but I missed the call while in the shower. I hope to speak with him today to inquiry about why my valves weren’t done with my tensioner. I plan to also share the bulletin info that was posted in this thread that outlines my problem that others have had.
Maybe it’s me, but if you look at my engine number above in this thread and look at the engine list from MB that shows which engines should get the valves and or tensioner repair I think my engine is not in that range. Or am I reading it wrong? I have been working super long days on a business project so I could be seeing it wrong.
Also all of my tensioners weren’t replaced, so I guess in theory it could be one of the other ones that didn’t get replaced that is bad right?
Old Sep 1, 2021 | 05:02 PM
  #39
Baltistyle's Avatar
Can’t speculate without opening. My engine was not in range for what it needed and I think the info about replacing worn valves is pertinent. To check
Old Sep 1, 2021 | 05:12 PM
  #40
SL 400
Yeah I get it.
Service adviser still hasn't returned my call yet, but I did get a nice $300 text bill about my diagnosis fee from that dealership though. Funny how that works, when he hasn't returned my call yet. All this hassle better nt be because they did my tensioner without doing my check valves!
Non mechanic question for you or anyone. Say I do have to do this check valve, is it a whole big thing to go back in and do after the tensioner was already competed, or can you get too and replace one if not all of them easily compared to the tensioner? How much would a check valve swap cost?
Thanks as always...
Old Sep 1, 2021 | 06:05 PM
  #41
Yeah I get it.
Honestly, they could have just have easily done the full install and not billed you for it. Or perhaps they have a record it’s been done in the Service History /VMI. And since your engine is outside the range maybe they decided to take the short cut.
I would ask a lot of questions…
Also easy to park the car in a warmer garage to see if it has any effect. (free) and put an oil pressure gauge to see pressure and how long it takes to get oil to the top end. (cheap). I definitely would be hesitant to throw more $$$$ at the problem without clear direction.
There is some very sage advice in Baltistyle three rules and post
Research your state laws for return if you ever get stuck in this situation. Time is of the essence
Good Luck let us know how it turns out.
Old Sep 1, 2021 | 07:07 PM
  #42
chassis's Avatar
2017 GLE350 4MATIC
@ThatsMyDawg Your engine is in the affected range, see line item numbered 1) .
Your engine number is #130705. Engines from #0 to #365996 require check valves and tensioners. Your engine requires check valves and tensioners.
It seems to be difficult for you (not a criticism) to get information on whether or not check valves AND tensioners are installed in your engine. If they are installed, all of them, your problem lies somewhere else, or the valves or tensioners have failed. Rare but it's possible. If they are not installed, you need them installed.
Quotes from earlier posts:
From ThatsMyDawg: Good info. My engine # is 276825 30 130705
from crconsulting “Engine 2769:
Old Sep 1, 2021 | 07:10 PM
  #43
chassis's Avatar
2017 GLE350 4MATIC
Yeah I get it.
Thanks as always...
@ThatsMyDawg This whole topic is a fair amount of work. You can use the search feature to see if anyone on this site has posted their experience with cost or labor hours. My guess is around 8 hours, so at $200/yr roughly $1,600 in labor plus parts of a few hundred. So roughly $2,500 for check valves and tensioners. I am shooting from the hip on this and giving a rough estimate. It's not a 1 hour job, and it's not a 1 week job. It's a day or two job.
Old Sep 1, 2021 | 08:00 PM
  #44
SL 400
I agree with you and did not take it as a critique. It is hard for me because I have to wait for people to return my calls. Outside of that all I have is my I invoice that says one (1) tensioner was installed with no check valves. My service manager replied to my email today after we have been playing phone tag for days. I am scheduled to speak with him tomorrow. I will ask every question I can think of as well as everyone those in this thread have suggested. Oh snap! I do have my VMI. I remember that I got it from MB later after my purchase. Let me review that again tonight and see if anything like this work needed is on it.
EDIT----->>>> Nothing on VMI that shows any prior tensioner/check valve work.
Old Sep 2, 2021 | 12:11 PM
  #45
SL 400
That is what I was looking for, ballpark costs. I know what a tensioner costs, because I have that invoice. I was trying to understand if it is the same amount of work to do check valves as it is to do tensioner work. Since I had a tensioner completed I thought it may be far less to do the valve (time and cost) because of the tensioner already being done, or if it is the same either way because of what you have to do to get to the valves might be the same as it is to get to the tensioner. I will search...
Old Sep 2, 2021 | 04:36 PM
  #46
MBNUT1's Avatar
2010 E350 4Matic
Boy I sure don't get this. OP has a rattle / knocking noise during start-up. Dealer replaces tensioners. Noise is still there. The best guess for the fix is that the tensioners need to be replaced. If true the dealer is utterly incompetent.
Old Sep 2, 2021 | 04:49 PM
  #47
SL 400
if I had hair it would be falling out!!
Well, I spoke with the service person and presented him with my findings and questions. Via phone he said “It does appear that MB wanted the check valves done with the tensioners to fix your issue, but it looks like we did not do the valves. Your engine is listed as one of those to do the valves.”
”let us research this to make sure that is correct and we have everything in order, give me until Tuesday to get back with you”
Old Sep 2, 2021 | 05:16 PM
  #48
Very Lame…
As suspected, it doesn’t appear as though they did the check valves when they did the tensioners 🙁
Does the VMI show they were done at any time?
and btw they did do both tensioners. Both part #’s are present on your invoice.
Tensioners are 50% of the proper repair, especially if his engine # falls into affected range.
It may need both tensioners and check valves.
Old Sep 2, 2021 | 05:47 PM
  #49
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I would seriously be looking for a new dealer after you hopefully get this repair completed properly.
Old Sep 2, 2021 | 08:02 PM
  #50
SL 400
The VMI does not show any prior work on the subject. The VMI shows steady and regular dealer visits for mostly small service visits.
Correct, my service rep confirmed to me today that they did not do the valves with my tensioners service. What he couldn’t explain is why they were not done. He also confirmed that both tensioners were replaced and pointed out to me that they have two different part numbers on my receipt.
He also confirmed that my engine does fall into the affected range, but mentioned that he didn’t even see a part number for the valves in whatever system is was looking in.
Very Lame…
