SL/R231: TRUNK WON'T STAY SHUT
Old Dec 14, 2021 | 09:11 AM
Another Car's Avatar
SL 550
When I try to shut the trunk I hear some motors engage but the trunk pops open and will not stay shut. This has happened now a bunch of times. I try to shut it three or four times and it still pops open. Finally I manually close it, there is some resistance and it stays shut, BUT a picture on the car with the trunk open is displayed in the dash. It goes away when I stop the car. I looked for a limit switch to see if needed adjusting but can not find one.Has anyone else had this problem? A solution? Location of a limit switch? (2014 SL 550)
Old Dec 15, 2021 | 05:37 AM
JettaRed's Avatar
Veteran: Army
I had a similar problem with my 2004 SL500. I found that I had to make sure the doors were unlocked. Weird!
Old Dec 16, 2021 | 11:32 PM
IanMacK's Avatar
E350
Sounds like a problem with the latch/lock actuator. I seem to remember someone had a similar issue and had the actuator replaced.
Old Dec 17, 2021 | 09:15 AM
SL 550
As a last resort I sprayed some WD40 in the latch. Shouldn't hurt. I also ordered a manual, CDs. Hope it will give me some insight. Also in another post that I mistakenly got into they said there was a switch in the glove box that did stuff to the trunk. I'll check that out.
Old Dec 17, 2021 | 10:22 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
I just found this in the manual:
"If a KEYLESS-GO key s detected in the trunk,
the trunk lid opens again after it is closed. It
does not lock."
Old Dec 17, 2021 | 10:31 AM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
When we had our 2013, we had a similar issue, particularly when the weather turned cold. After chasing a number of other possibilities, it ended up being the trunk struts. Replaced them and the closing issue went away. Might want to check your struts if they have not been replaced.
Old Dec 17, 2021 | 10:53 AM
SL 550
I keep the KEYLESS-GO key in my pocket. If it happens again I'll increase the distance between the key and the car. Before I replaced the struts I'd want to be sure that was the problem but something to look at.
