SL/R231: Magic Vision Wipers?
Old Jul 29, 2023 | 08:13 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by ThatsMyDawg
…You are saying that zero fluid is coming out, not that it's just a weaker stream?....
Maybe an enlarged probate?
Old Jul 29, 2023 | 08:40 AM
ToeKneee's Avatar
R231 SL500
Or prostate.....
Old Jul 29, 2023 | 11:31 AM
JettaRed's Avatar
Veteran: Army
Guilty! (Damned autocorrect! Kinda spoils the joke.)
Old Jan 8, 2024 | 04:40 PM
Jcrew's Avatar
SL 400, GLC300, C300
Bumping this thread to see if anyone has any updated experience with the Magic Wiper system.
I replaced my washer motor myself about 2-3 years ago and performance improved for about a year and then stopped working (the washer part) completely. I took my car to an Indy shop and they installed a new washer motor this past summer (2023). I tried it in their lot when I picked up the car and passenger side was decent, driver’s side almost nill. I tried them again in October when I shipped my car to its winter home in Florida and no washer spray on either side.
Obviously I don’t use the car that much and even less in sloppy weather where the washer might come in handy. Still, I’d like to get the washer working as it’s supposed to. Hoping someone here has some positive experience.
Old Jan 8, 2024 | 04:51 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I recently replaced my wipers in an attempt to increase the amount of fluid to the driver's side. New wipers performed exactly the same. I am of the opinion that this is by design as the passenger side wiper does push fluid to the driver side.
Old Jan 9, 2024 | 01:42 PM
Jcrew's Avatar
I tend to agree that by design more fluid is released on the passenger side but my issue is I’m not getting any fluid out of either side. A new pump was installed only about 6 months ago. I’m starting to think that the problem is in the hose(s) from the reservoir to the wipers. I’m looking (hoping) to find someone that has had this same issue and solved it.
Old Feb 11, 2024 | 03:08 AM
  #32
95Sinned420's Avatar
2016 S550
Deleted
Old Apr 22, 2024 | 01:33 PM
  #33
metsche's Avatar
SL500
Some hint for you guys if you are not willing to pay 180 bugs for some magic wiper blades.
I always disassembled these friends and changed the rubber slice only. You get this rubber piece in the aftermarket shop for about 10 bugs. Invest 15 minutes and your wiper are new ones for 1/18 of the mercedes price.
Did this the last 6 years every year and always had a clear view
You need to remove the two black plastic end caps, then you can remove both metal rails (dont know if this is the right word lol), which is the heating of the wiper blades. Put the new rubber between and put it together and back into the mounting frame. Little bit tricky but no big deal to reassemble!
Regards,
Metsche
Old Apr 23, 2024 | 01:20 AM
  #34
rmorin49's Avatar
Veteran: Army
Regards,
Metsche
Any video of the process. Source for the rubber inserts? Thanks.
Old Apr 23, 2024 | 11:55 AM
  #35
Bitbytr's Avatar
'13 SL550 Mars Red, Designo White interior, B and O sound
(Not cheap, certainly, but I scored a pair for $120 recently.)
Old Apr 23, 2024 | 10:23 PM
  #36
JettaRed's Avatar
Veteran: Army
I'm on my third set and only paid for the first set thanks to FCP Euro. I replace them about every 6 months.
Old Apr 24, 2024 | 01:21 AM
  #37
ToeKneee's Avatar
R231 SL500
Wish we had a similar retailer in the UK!
