SL/R231: Magic Vision Wipers?
I think I remember seeing more than one line going into each blade. Is this correct and how is the fluid heated?
The washer motor is located at the bottom of the washer reservoir which is on the passenger side. I had to take off the front tire and remove the wheel well plastic shield. It’s actually not too difficult and there’s a great YouTube video on it.
Dr. Manhattan, when your SL is out of warranty you might start searching for an Indy as well.
Funny that we started this talking about wipers. On my last long drive, my windshield took a small stone hit/chip...but the result is that the top[ right corner of the glass now has a 7" crack in it. I had the dealer give me an estimate while the car was there. Just under $1700 for the window/kit. and another $600 for the installation. A chunk, for sure. It's hard to pony up that amount for something that could happen again right after fixing it.
That is crazy!!
You will also need to read the temperature of the transmission fluid in the process of changing it out. I recommend everyone should have a scanner like this anyway if you own a Mercedes. It's small enough to fit in the cargo space in the trunk.
iCarsoft MB V3.0 for Mercedes-Benz/Sprinter/Smart Diagnostic Tool with auto VIN/Quick Test/Actuation Test (amazon.com)
Mercedes Windshield Wiper Blade Set - Genuine Mercedes 2318201045 | FCP Euro
FCP Euro Lifetime Auto Parts Replacement Guarantee | FCP Euro
While at the beach a year, or so later I saw another SL owner. We chatted a bit and then I remembered my wiper concerns. I asked if he would mind if I looked at how his wipers worked to compare them to mine. Our cars were literally parked beside each other. Sure enough his passenger side seemed to spray much more solution than the drivers side. That does mean that something is not wrong with your wipers though, but it is interesting that it's the same side I thought my issue was on and it's also the same side that I confirmed with another SL that was the same as mine..
You are saying that zero fluid is coming out, not that it's just a weaker stream? I had to look hard at mine before I could see there was fluid coming out of the drivers side....I would double check that the hose is connected properly at that side. It may have not been seated all the way and has worked its way off over the 10k miles....
While at the beach a year, or so later I saw another SL owner. We chatted a bit and then I remembered my wiper concerns. I asked if he would mind if I looked at how his wipers worked to compare them to mine. Our cars were literally parked beside each other. Sure enough his passenger side seemed to spray much more solution than the drivers side. That does mean that something is not wrong with your wipers though, but it is interesting that its the same side I thought my issue was on and its the same side that I confirm with another SL that acted the same as mine..
