SL/R231: Are there all-season run-flat tires for W231?
Old Feb 2, 2022 | 09:23 PM
ladzio's Avatar
'11 BMW 328 / '07 911 Targa / '17 MB C300
I am in the market to buy a W231 for my wife and I realized I have a practical hurdle to overcome: lack of all-season run-flat tire option. This would be a daily driver in NYC area so summer tires are not an option. Second, if my wife gets a flat, I want her to be able to get home and not be stuck waiting for a tow truck: hence a need for run-flats (which is what she had on her cars for last 10 years). Carrying a spare in trunk will not do.
For last two days I searched the Internet for all-season run-flat availability, called Tirerack, but nothing. Am I out of luck?
Old Feb 3, 2022 | 09:46 AM
JettaRed's Avatar
Veteran: Army
What did you do the previous 10 years?
Old Feb 3, 2022 | 09:47 AM
JettaRed's Avatar
Veteran: Army
AmazonSmile: AirMan ResQ Pro+ Tire Repair Kit : Automotive
Old Feb 3, 2022 | 08:03 PM
ladzio's Avatar
Over the last 8 years she drove '07 MINI Cooper on runflats - those saved the day more than once. For the last 2 years she has been driving a '17 MB C300 on runflats - no flat tires so far. My goal is not have her stranded on a side of the road waiting for a tow truck, or trying to get glue in a tire from a repair kit, or hope for someone to put a spare on (plus I doubt a big rear wheel would fit in the trunk).
Old Feb 3, 2022 | 08:12 PM
ladzio's Avatar
I may have found an answer to my question although I do not like it:
Use MB OEM 17" Rims (appears to be a squared set up), which take tire size 255/45R17. In that size TireRack has 5 all-season run-flat tires.
Old Feb 3, 2022 | 09:25 PM
Rick F.'s Avatar
2020 SL550
ladzio,
OEM Mercedes wheels are extremely expensive, as I'm sure you know. TireRack has 18" and 19" wheel and tire packages with a pretty wide choice of non-OEM wheels and a number of all-season runflats. You could mix and match to get a non-square setup with 19" wheels.
Alternatively, you could keep using summer performance tires on your existing wheels and get a TireRack wheel and tire package for winter tires. Your local dealer or one of the TireRack-approved installation centers could just swap them back and forth as necessary. If winter use is expected, this would be a much more effective approach than using all-season tires.
Rick F.
Old Feb 5, 2022 | 09:38 AM
ladzio's Avatar
Good idea. There is a set of run flat winter tires to go with aftermarket 19" rims on TireRack.
