SL/R231: Massage not working
Old Feb 6, 2022 | 12:07 PM
vmaxhp's Avatar
SL550 - 231
Massage not working
Good morning! New owner of a 2015 SL550 White Arrow. I just took ownership the other day and am trying out all the features. On the drivers seat massage settings, I can click any of the options 1-4, and the Massage setting indicates my selection. Then, a couple of seconds later, the selection reverts back to 0 (Off), and I can no longer select any of the 1-4 options. Thoughts?
Thanks!
Rick
Old Feb 6, 2022 | 02:09 PM
Wolfman's Avatar
Super Moderator
This is typically a failure of the pump or a leak in the bladder. Are you hearing the pump at all? Just compare to the passenger seat...
Old Feb 6, 2022 | 09:14 PM
rj96mb's Avatar
2013 SL 550
The same thing happened to me on a recently purchased SL 550. Both side bolsters in the drivers seat only holds air for a few seconds and I hear a hissing sound. Sometimes it will not inflate at all. I would like to know if that means it is the bladder(s) or a valve leaking or what. The passenger seat works fine and stays inflated. If it is seat bladders what is the cost to repair?
Old Feb 7, 2022 | 12:54 AM
vmaxhp's Avatar
SL550 - 231
Thanks guys! I'll have them check it out.
Old Feb 7, 2022 | 03:36 PM
Georgecatl's Avatar
2013 550SL
I recently purchased a '13 550 SL with the same issue in the passenger seat. Good info here and something I can take back to the dealer. I've got a 90 day warranty to sort all this out.
Old Feb 8, 2022 | 09:18 PM
IanMacK's Avatar
E350
I hope your warranty covers it. It is usually expensive to replace the bladders and tubing.
