SL/R231: Measure Gains from "chipping"?
The often quoted reassuring "Full front & rear '4' wheel alignment" is only Toe, directional adjustment.
Then the frustration of being told nothing more can be done - "is within (the broad parameter) of factory specs".
It is all to do with cost cutting and ever increasing speed of auto assembly lines !
We saw the need therefore to reinstate once again from the early 90's Front Camber (and Caster), Rear Camber (and extra Toe). Bolt-on no mods. Precise single wrench adjustable.
Catering for other then showroom height conditions - day to day commuting encountering high cambered roads, wheel squat through load carrying or lowering, fitting wide profile tires or simply the ability to have ongoing adjustment for curb knock damage.
R231 all incl. AMG
Front Camber & Caster #502216K $480
Camber Only #502216-1i $345
Rear Camber (& extra Toe) #502126-1K $480
My wife has a 2019 Vette, her car is faster overall, but the experience in the SL is alot more fun. And if you are a chubby person like me getting in and out of the SL is a dream compared to the vette. And while off the line the Vette moves out faster, I think the response when punching it at 50-55 - the SL takes it hands down.
I recently spent a weekend with my Dad's BMW 2019 850 csi - A heavy car with quite a bit more power than the SL. And while I haven't gone head to head against my Dad, I'm pretty confident the SL will take the BMW up to about 75-80 after that it's hard to say because the BMW seems to pull hard, but the SL is much faster getting through the gears. And the BMW's response when punching it at 35 or 50 or 55 - is nothing like the SL.
As for the Weistec upgrades. To get the numbers out of the turbo upgrade you need to change out the Exhaust system and take out the cats. Which takes the classy SL and makes it so you can't drive home after dark without waking the neighbors.
I haven't looked in the last year or so, but there also isn't a single review, comment, or anything from anyone that has done the turbo upgrade, including Weistec. Weistec is within an hour from me, and I had reached out to them several times, but could never get much specifics other than, it's going to be really loud.
Dave B
Remember, hp is generally a function of fuel, air, compression, and timing. More hp usually means more fuel. Also, if you're not going to drive it like it should be driven, why spend the money on an upgrade?
R231 all incl. AMG
I'm checking out your catalog online, but it's kind of tough to decipher for someone who didn't lay out the info. If I'm reading correctly, on the rear there's a choice of whether you adjust the camber at the top or at the bottom? Are some of the part numbers for ABC, and others without? A bit confusing...
I just watched a YouTube clip of a guy who just does videos of himself tearing down various engines that have failed. This vid was on the M278. I think the lower end of one of the rods had let go due to something getting in between the rod bearing and crank journal. Sad. What was really interesting was the exhaust manifold/turbo setup. The log-type manifold was one piece with the turbine housing! It's pretty tough to get more efficient than that...though the manifold half was just a log with holes in the side that line up with the exhaust ports in the head. I've read a lot about turbos over the years, and I'm always amazed at how horrible some of the exhaust manifolds look (like these), compared to how well the whole setup actually works.
