SL/R231: Auxiliary Battery Malfunction
What's a good source other than the dealer for a replacement? Anyone know the model number?
OEM Starter battery (AGM)
Pt No. A 001 982 82 08 26
Capacity 95 Ah; Start amps (CCA) 850 A
Vlies-Technologie
Dimensions: mm L353 W175 H190
Alternate Starter battery (AGM)
Varta SilverDynamic AGM 95Ah with OEM code (595 901 085 / G14 / 019AGM)
Aux battery (AGM)
A211-541-00-01
Good luck!
Not sure if it requires coding afterwards to remove the "error" warning.
Happy Holiday
Happy Holidays to Everyone!
https://mbworld.org/forums/sl-class-...t-guide-2.html
Take your time and don’t use force.
The only thing I can add is be careful not to arc the terminals at any time. Remove negative terminal first as mentioned in the guides. And watch where you swing your wrenches! These cars are sensitive to voltage spikes/shorts and accidentally grounding the battery/circuits can lead to electrical issues. On some cars, as I’m removing and replacing the battery. Terminals can flop around or go in weird places/angles. If I find myself wrestling with a battery too much, I’ll temporarily wrap the terminals in electrical tape so they don’t strike the battery terminals until I’m ready to bolt them them up just to be safe.
That battery is pretty light, and access is decent. So you should be good. But just be vigilant with those terminals and what your doing around them.
Happy Holidays and good luck!
https://smile.amazon.com/dp/B0090ULA...v_ov_lig_dp_it
Added: I just found a Mercedes dealer in Tysons Corner, VA that will sell the OEM battery for $119 and ship it to me at no extra cost other than sales tax. I'm going to go with this option.
Update: Dealer said they cannot ship the battery so I'm back to the Amazon option. Also found an alternative that is supposed to be equivalent to the OEM battery for half the cost. I might try it as it is a local store and I can return it if the fit isn't perfect.
I guess I will order one from my local dealer unless I can find one online. Found an OEM Mercedes battery online from Amazon. I'd like to confirm the date code but guess I will order it and hope for the best. The date code on my original battery was 29 14 so I think regular maintenance does help these AGM batteries last longer.
Was the battery cage modified, i.e., tabs cut for easy removal?
Good luck!
Btw, the M-B part number on my original 2017-vintage AGM auxiliary battery (dated 39/16) is A 000 928 70 08. It's rated at 12Ah, 170A EN, and it was made by Fiamm.
Also, is it charged while driving? I am impressed by the long life of the auxiliary battery in my 2015. It has a date code that makes it almost 8 years old! I ordered the same battery as a replacement. Still waiting for it to be delivered.
I will continue to use a CTEK on both batteries as I will reconnect a pigtail to the auxiliary battery. Former owner installed it and I think it helped it last as long as it has.
Happy Holiday
Thanks.
Full charge immediately after charge should be about 13.7 volts for the aux battery. It should settle in to about 13 volts after a couple of hours.
Last edited by hornethandler; Jan 11, 2022 at 09:49 AM. Reason: Clarify full charge state.
