SL/R231: Seatbelts and Water
You always want to find and fix water inside the car. Your carpet may not be wet, but that doesn't mean there's not water underneath in the floor pan. I'd pull up the carpet to be sure. I've posted elsewhere about my 2008 Infiniti G35x that was infiltrated by water and started to act weird. If wires get wet, they can wick water into connected electronics and then you have phantom problems due to shorts and corrosion. My insurance company totaled the Infiniti as flood damaged because they knew that it would always have problems after that. The strange behavior of the car was not starting or after starting, not shutting off. I had to disconnect the battery to stop the engine.
I started to have similar problems with my 2004 SL500 and found that the water drain under the air vent in the hood in front of the passenger seat was clogged. Fortunately, after I cleaned that out, the car stopped going whacky with the electronics.
Video below may also help (you'll need to view on YT, click link) R231 procedure is pretty much the same. (notice where the water was leaking)
Next time I'm in the WIS/EPC, I'll see if I can post a diagram & exact location of all drains
Also this may help:
https://mbworld.org/forums/sl-class-...of-noises.html
Good Luck.
