SL/R231: R231 Camshaft Sensor Question
Old Jul 14, 2022 | 03:31 PM
Okieonekenobi's Avatar
2014 SL550
I am new to this forum. I just purchased a 2014 SL550 last week. While going through this site I find threads on the camshaft sensor oil issue. So I went out to the car and tried to remove a connector and inspect for oil migration. After flipping up the white locking clip, I could not pull the connector off. Am I missing something? I do not want to break the connector. Is there an additional clip or something? Thanks in advance for any help.
Old Jul 14, 2022 | 04:08 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Welcome
this is a good read for connectors and how they function. (see post #4)
https://mbworld.org/forums/e-class-w...ustration.html
Those connectors can be a bit tight if they haven’t been off in a while. But don’t go ape on them. 😀
Good Luck
Old Jul 14, 2022 | 05:11 PM
2014 SL550
Thank You
Old Jul 16, 2022 | 10:58 AM
Thank You
Did you find oil in your connectors or were they dry?
Old Jul 16, 2022 | 12:18 PM
chassis's Avatar
2017 GLE350 4MATIC
It takes practice to get those connectors off reliably.
it’s a release-squeeze-pull action
release the locking clip
wiggle the connector and gently push it toward the sensor, in the direction of installation
while gently pushing the connector toward the sensor, gently but firmly squeeze the locking clip
while squeezing the locking clip, lightly wiggle and slowly pull the connector off
Repeat this process until the connector is removed. Don’t force anything.
Wiggling frees the dust and grime that may be present. Pushing and wiggling helps to release the locking clip if it hasn’t fully released yet.
Old Jul 16, 2022 | 01:22 PM
2014 SL550
I will this weekend. I will let you know what I find
Old Jul 18, 2022 | 04:31 PM
2014 SL550
Yes, I found oil in two of the connectors. quite a lot of oil. I have an extended warranty that covers the sensors and wiring harness if it gets to that. No oil in the computer.
Old Jul 18, 2022 | 04:32 PM
2014 SL550
Thank You, that was a lot of help.
