SL/R231: Water Pump Bolt Torque specs
Hello,
Does anyone know what the torque specs are for the water pump mounting bolts and sequence? The are the Torx bolts that bolt the water pump to the engine.
It is a 2012 mercedes sl550 V8
And last question, though I see the letters, there is no actual numbered sequence where to start. Would you start from the middle proceeding diagonally and across working your way to the outside?
2020 GLC300 -2013 Sl550 - 1997 SL600
see attachment,
It goes without saying, if you’re going to work on these cars, I would at least recommend getting the WIS.
Good Luck
