SL/R231: Navigation Question, 2013 R231 SL63
Map settings
Call up the map settings menu
- To show the menu: press the COMAND controller.
- Select Navi in the main function bar by sliding and turning the COMAND controller and press to confirm.
- Select Map Settings and press to confirm.
The map settings menu appears.
Map orientation
Possible map orientations:
- North orientation (The map view is displayed so that north is always up)
- Heading orientation (the map view is aligned to the direction of travel. The direction of travel is always at the top, the Map operation and map settings
- Bird's-eye view (the map view is aligned to the direction of travel. The map projection reproduces the curvature of the earth's surface)
- 3D map (the map view is aligned to the direction of travel. At a scale of 1 km the map displays elevation)
Good Luck
Gary
Sorry I don't have another idea for you. Very curious. I hope someone else can help.
Gary
to get the vehicle build sheet
in my case code 168. Command NTG 4.5 gen 2
Do you have the owner's manual?
If not it's available free to download from the internet.
Try looking on page 374 "Map Orientation"
The only other thing I can think of is that you don't have the official MB maps.
Good Luck.
Good Luck.
Local Dealership charged me $1,750 for updating the ECU, TCU and Navigation. The navigation is now working as it should. I don't understand why it needed to be updated in order to work as it's supposed to, according to the manual. Thank you all for your feedback.
