SL/R231: Airscarf only allowing low setting?
Old Jan 17, 2023 | 05:28 PM
SLAMGUK's Avatar
SL
Hi all
I’ve recently purchased a used (R231) SL350 AMG and I’m only getting the lowest setting (one red light) on the airscarf button, both on the drivers side and also the passenger side. I can hear it working, hot air from both sides, no issues in that respect, but I’m only getting one red light for both, it’s basically and on/off button as it stands. Has anyone else had the same issue?
Any help or insight would be much appreciated, it works but I’m sure something is obviously faulty?
Thanks in advance.
Old Jan 18, 2023 | 11:26 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
There’s a control module mounted in the back of the passenger compartment, you could probably start by troubleshooting that module. It probably stored a code that can be read by XENTRY.
https://www.mbpartscenter.com/oem-pa...ItOTAwLTA0LTAy
I posted the WIS here:
https://mbworld.org/forums/sl-class-...air-scarf.html
