SL/R231: Squeaking Drivers Door
Old Feb 1, 2023 | 04:15 PM
griza's Avatar
2006 CLS55 AMG Sold 2010 E550 Coupe totaled by mechanic, '13 SL550 I totaled it, 2017 SL63 current
When opening and closing, my drivers door has developed a squeak. Can I just hit the hinges with WD40 or would something else be preferred? Anyone else with a squeaky door?
Old Feb 1, 2023 | 11:55 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
I would go with spray white lithium grease over WD40 if possible
There have been a few door hinge issues:
https://mbworld.org/forums/sl-class-...oor-creak.html
Good Luck
Old Feb 2, 2023 | 06:18 AM
rorywquin's Avatar
Shanks’s Pony
WD40 is a degreaser. As suggested, use white lithium (the makers of WD40 also make it).
Old Feb 3, 2023 | 02:23 AM
toi's Avatar
toi
2014 sl550
you can try to lube the hinges and hope it works.
our doors have magnetic system to hold it where you leave it open and it has gears i believe situated in the door panel. it might also be cause of the sound.
Old Feb 3, 2023 | 03:28 PM
griza's Avatar
Thank you, I ordered some white lithium grease. I appreciate the help and recommendation to not use wd40.
Old Feb 5, 2023 | 04:50 AM
rorywquin's Avatar
Shanks’s Pony
Use a cloth around where you are spraying - it can be messy.
Old Feb 5, 2023 | 09:18 AM
griza's Avatar
Thank you Rory, yes I had planned to do that. Appreciate the help!
Old Feb 6, 2023 | 06:10 PM
ThatsMyDawg's Avatar
SL 400
It is not an instant fix and takes some time for complete penetration. You want to work it in the joints, etc with a gloved hand. Opening and shutting the door numerous times will also get things started, but it takes a bit to work its magic.
