SL/R231: Battery Saver for auxiliary battery
Old Apr 10, 2023 | 07:38 AM
SLDOUG's Avatar
2013 SL 550 R231
I am Looking to change my auxiliary battery (The one behind passenger seat) on my SL550
Do I need to install a battery saver as you do for the main battery to protect all memories and settings
Thank you,
Regards
SLDoug
Old Apr 10, 2023 | 10:37 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
It is recommended by MB that you disconnect the negative terminal on your MAIN battery before replacing the auxiliary battery. So you probably will want a memory saver device if you wish to preserve your preset's.
Old Apr 10, 2023 | 11:33 AM
SLDOUG's Avatar
2013 SL 550 R231
Thank you for the info
Regards
SLDoug
Old Sep 29, 2025 | 04:42 PM
andy-gts's Avatar
sl63 amg
just changed mine , didnt disconnect the main battery, all is well, no electronic gremlins...2014 sl63
Old Sep 29, 2025 | 05:56 PM
Excellent, for what it’s worth, the WIS for the R231 Aux Battery Removal (see attached) specifically doesn’t mention disconnecting the main battery. But MB’s latest “blanket” recommendation is based on how different BCM’s are very different from model to model. Some WIS specify disconnecting the main battery, some don’t. Some BCM’s have to also be reset. If I was working on someone else’s car, I would disconnect it out of precaution.
Luckily, the R231 BCM is relatively simple, and disconnect's when it’s not being charged and off.
Good Luck
Old Sep 30, 2025 | 08:04 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Another interesting tidbit is that you don't need to put a memory saver on the R231 when changing the main battery. I have disconnected the main battery negative terminal many times on my 2014 SL for days while working on it and have not lost any settings.
Old Sep 30, 2025 | 08:58 AM
JettaRed's Avatar
Veteran: Army
Not to mention a complete disconnect of both batteries help reset some stored parameters that may be causing "problems". I'm not really sure which settings might be affected that don't relearn everything after a few hundred miles. The only thing I can think of is maybe the anti-pinch settings for the automatic windows. But that is easy enough to fix.
Old Sep 30, 2025 | 11:35 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I replaced my auxiliary battery a couple years ago, did not disconnect the main battery. No issues and no loss of anything.
