SL/R231: oem wheels
Old May 11, 2023 | 05:50 PM
rmp65's Avatar
sl65
oem wheels
Does anybody know if the 21inch wheels and tires from a 2022 550 sl will fit on the 2013 sl.
Old May 11, 2023 | 06:21 PM
Wolfman's Avatar
Super Moderator
The new R232 SL has larger wheels and tire diameter than the R231.
So as a direct bolt-on that would be a no.
The R232 uses a 35F/30R tire on a 21” rim while the R231 has the same for 19” wheels (for diameter reference).
Given that the offsets of the R232 are much higher (56F/67R) vs the standard R231 19” at 34.5F/48R, they should fit with large wheel spacers. I am thinking 25mm, but likely 30mm.
You will just have to get smaller diameter tires. Am thinking 30/25 but a tire calculator will give you specifics.
Personally I would get 20” forged cross spoke AMG wheels from another AMG model before taking R232 take-offs
Old May 13, 2023 | 10:21 AM
rmp65's Avatar
sl65
wolfman
Could you post some pictures of the wheels you are referring to. Thanks.
Old May 14, 2023 | 03:02 PM
Streamliner's Avatar
Go to: www.alloywheelsdirect.net
You can see most all MB & AMG wheels that have been available for the past several years. Great company to buy from as well.
