SL/R231: Leaking Roof
Old Jan 9, 2024 | 06:55 PM
JettaRed's Avatar
Veteran: Army
Leaking Roof
We've had some heavy rain and I noticed my seatbelts feel damp. Upon closer examination, there are droplets of water on the inside next to the rear side windows. I've opened the roof and made sure the seals were all in place and treated, but I'm still getting water in. Any ideas on how to fix this?
Thanks.
Old Jan 9, 2024 | 08:54 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Originally Posted by JettaRed
We've had some heavy rain and I noticed my seatbelts feel damp. Upon closer examination, there are droplets of water on the inside next to the rear side windows. I've open the roof and made sure the seals were all in place and treated, but I'm still getting water in. Any ideas on how to fix this?
Thanks.
Though a pain, window adjustment usually can fix it.
Early cars had a TSB about this issue
https://static.nhtsa.gov/odi/tsbs/20...35951-9999.pdf
Good Luck
Old Jan 9, 2024 | 09:31 PM
JettaRed's Avatar
Veteran: Army
Thanks. Mine's a 2015. However, I'll still ask.
Old Jan 9, 2024 | 09:38 PM
The early cars had the weatherstripping replaced….
But the window adjustments compensate for the weatherstripping stiffness and plastic deformation that happens over time on all cars.
Theres a section in the WIS on how to make the adjustments.
Old Jan 9, 2024 | 10:01 PM
JettaRed's Avatar
Veteran: Army
I think I found it: ar67.30-p-4200rk
File Type: pdf
Old Jan 9, 2024 | 10:05 PM
Thats it, there’s a front window adjustment too. Just going to depend on where your leak is.
Good Luck.
Old Jan 9, 2024 | 10:08 PM
JettaRed's Avatar
Veteran: Army
The leak seems to be coming from the rear window, though I thought it was the roof hinge area as that's where it appears to drip from. I will look more closely as soon as the rain stops, now that I know what to look for.
thanks again!
Old Jan 10, 2024 | 03:17 PM
JettaRed's Avatar
Veteran: Army
Here is with the passenger side door open and the rear window retracted.
Here is with the door closed. The rear window closes snugly. Also, there was no water running down on the inside of the window, but rather dripping from the roof near the hinged area.
Old Jan 10, 2024 | 04:26 PM
JettaRed's Avatar
Veteran: Army
The dripping was in this general area.
Old Jan 10, 2024 | 04:33 PM
Always tough to tell from pictures/internet but looks like the upper part of the weatherstripping isn’t sealing or maybe it’s worn?
Use 1” wide (or less) THIN strips of paper or plastic to see if the seal is loose anywhere (and tension is even) when closed…
I’ve used cut plastic bags
The rear window has a “pre tension“ adjustment that puts pressure on that top area of the window. But all the weather stripping seal should be smooth & soft too.
Old Jan 10, 2024 | 05:14 PM
JettaRed's Avatar
Veteran: Army
I'll give that a try. But as I noticed, the inside of the windows were not wet.
Old Jan 10, 2024 | 05:20 PM
Could be roof seals, If only one side is leaking compare it with the side that’s not…
those panels are also adjustable 🙁
Old Jan 10, 2024 | 06:22 PM
JettaRed's Avatar
Veteran: Army
Of course. You coming to Maryland anytime soon?
Old Jan 10, 2024 | 08:02 PM
Im sure you’ll find it. First step is finding the leak. Water can travel too 🙁
Sometimes, it’s easier just to replace the weather stripping. You just need to find which one.
Good Luck
Old Jan 10, 2024 | 08:49 PM
TomZVB's Avatar
R231 SL 63
The rain we’ve had down here in Hampton Roads was unreal. If what came down in your area was close to what we had here, then I don’t doubt at all that it leaked!
Very glad to have gotten the SL in the garage the day before all hell broke loose yesterday.
Looks like we’re expecting another round of it Friday, too.
Good luck with finding the leak!
Old Jan 10, 2024 | 09:22 PM
Some Vario Roof basics.
R230 and R171 centric, but fundamentally the same diagnostic principles:
https://nsk.mercedes-benz-clubs.com/...oting-tree.pdf
Old Jan 10, 2024 | 09:38 PM
JettaRed's Avatar
Veteran: Army
Thanks! I think this might be it. Certainly sounds like it for Pos. 2.
Old Jan 12, 2024 | 06:59 AM
ThatsMyDawg's Avatar
SL 400
OMG dude I said the exact same thing yesterday. When I got back in my car after a week, or two of it sitting and the hard rain here my front seatbelt on the drivers side was damp. Second time it happened after a hard rain. I always forget to check the passenger side.
I have washed my car a million times with a high pressure water hose and always dry as can be.
Thanks.
Old Jan 20, 2024 | 05:46 AM
paw777's Avatar
R231
Hi all - same issue here on my 2014 R231. Did anyone manage to work out a fix?
Cheers
Old Jan 20, 2024 | 07:07 AM
SL 400
No.
I haven’t looked into it further as it is a non issue during winter time.
It seems to be an issue during very heavy rains only and a those don’t exist here this time of year.
The issue will be revisited come spring when I can take it through a car wash and look for any leaks while sitting in the car.
At some point when all the snow and salt has been washed away from the roads I may take the SL for a wash before the spring. Will check into the issue more whenever the next wash comes.
Cheers
Old Jan 20, 2024 | 08:55 AM
JettaRed's Avatar
Veteran: Army
I'm taking my car into the dealer Monday to repair my passenger seat. I will ask if this is a often reported problem or an easy fix.
Old Jan 21, 2024 | 03:38 AM
ToeKneee's Avatar
R231 SL500
You'll get the standard Mercedes quote of "No sir, the SL never leaks, ever, and certainly not in that place!" 😱
Old Jan 21, 2024 | 07:59 AM
paw777's Avatar
R231
This is exactly what they said to me, but said they’d “look at it” and did some “adjustments” that ended up costing £250. Still no luck.
I also then took it to a “roof specialist” and similar story there…
Old Jan 21, 2024 | 08:32 AM
JettaRed's Avatar
Veteran: Army
@ToeKneee and @paw777 in which case, I'll show them the Vario Roof Troubleshooting Tree. But, if I have to do that, I probably don't want them to work on the car anyway. Ideally, they'll know exactly what the problem is and can advise me what can be done. Then I can decide what to do.
My weatherstripping is soft and pliable, and all the windows fit snuggly, so when it warms up a bit, I'll look closely for possible points of ingress.
Old Feb 6, 2024 | 12:09 PM
cenabaki's Avatar
2005
Thumbs up
Thanks.
checking the roof seals. Here are a few quick fixes to try
  1. Check the door seals for wear or damage.
  2. Inspect the seals around the rear side windows for cracks.
  3. Clear out any debris from the drainage channels around your vehicle.
If these don't work, it's best to consult a professional mechanic for further assistance click
