SL/R231: Massage sometimes doesn't work - buzz sound
Old Jun 17, 2024 | 12:40 PM
billvp218's Avatar
m157 SL63
My driver's side massage has often not been working lately. When I try to turn it on (selecting options 1-4), if it makes a buzz sound (it seems like it is coming from behind the right side of the driver's seat) then it won't work. It usually does this sound twice. Sometimes it will work for a little while, then make the 2-buzz sound and stop working. I'm wondering if anyone knows what this sound means. It only does the buzz sequence once per driving session. After that, it will still not work if I try it again but will not make any additional sounds.
The dynamic seat bolsters work fine.
I watched the video here:
and the leak didn't have this buzz sound. I have an iCarSoft but it doesn't have anything to read the massage seat functions, as far as I can tell. There is a driver's seat option, but it just shows things like seat positioning and easy exit.
Old Jun 18, 2024 | 10:18 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
It sounds like you may have an leak.
Does everything (side bolsters and passenger seat functions) stop working once the massage stops working? If so, it's possible the pump is shutting down to protect it from over heating. This would also explain why it is working intermittently, i.e. the pump resets after a period of time.
The two buzzing noise may be the pump's initial activation, and the subsequent activation to compensate for the leak.
Mine did something very similar... I heard the pump's first activation, then, after a short period, a second activation before the pump went into protection mode and shut down at which point everything (massage and active side bolsters) on both seats stopped working. After a period of time (a few minutes) the pump reset and everything started working again.
Here's a link where you may find some useful info.
https://mbworld.org/forums/sl-class-...lfunction.html
Good luck.
Last edited by hornethandler; Jun 18, 2024 at 12:24 PM. Reason: additional pump info
Old Jun 19, 2024 | 01:04 AM
billvp218's Avatar
m157 SL63
Good luck.
The side bolsters still work even if the massage is not working. When the driver side massage does work, there are no buzz sounds upon it activating.
There are no issues with the passenger side. Everything works, and no buzz sounds.
Old Jun 19, 2024 | 01:23 AM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
My massage feature doesn’t work and I don’t get any buzzing sounds. Leak? Fuse? ?????? It did work for a while right after purchasing, but quit shortly thereafter.
Old Jun 19, 2024 | 01:36 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
I haven’t used massage feature yet. None of my passengers have either.
Among the reasons I don’t use it, is because I don’t want to have the same problem as the OP.
But I am also worried that they could decay from disuse.
Old Jun 19, 2024 | 07:09 AM
Since it seems isolated to the driver’s side massage function, you could start by checking the “driver’s seat massage function actuation motor” and related components.
Attached are some shop docs—originally provided by crconsulting—that will help you find the seat components.
Since the passenger side is working, it may be possible to swap/slave in a passenger side part to confirm the bad driver’s side part.
Old Jul 22, 2025 | 04:21 PM
mario2505's Avatar
Sl r231
The same case
I watched the video here: Troubleshooting Mercedes-Benz Seat Massage Dynamic Support (youtube.com) and the leak didn't have this buzz sound. I have an iCarSoft but it doesn't have anything to read the massage seat functions, as far as I can tell. There is a driver's seat option, but it just shows things like seat positioning and easy exit.
Hi!
Did you resolve the issue with massage ?
I have exaclty the same case with buzzing,
sometimes work 1 minute sometimes longer… I would be very thankful for help.
