SL/R231: Magic Sky Control stopped working
Old Jun 25, 2024 | 01:07 PM
Nasser_Almoumen's Avatar
2017 SL 500
Hello fellow members,
i have a 2017 R231, magic sky control stopped functioning, i took it to a independent mechanic he checked the module, fuse and the wiring, there was nothing wrong with them so he told me it should be the glass panel that’s damaged probably from parking it under direct sunlight and it needs to be replaced, waiting on a quote for the price of a replacement part.
- has anyone encountered similar issue where he had to replace the unit ? Is it a common issue ?
and is it possible to get damaged by the heat and prolonged exposure to sun ?
Thank you.
Old Jun 25, 2024 | 01:41 PM
Keon's Avatar
SL550
It might be more cost-effective to retrofit the sunshade from an SL without magic sky control than to replace the panel. I doubt sun exposure is what damaged it - magic sky control is somewhat known to be problematic. The LCD tends to fail, and it requires replacing the entire panel to fix.
Old Jun 25, 2024 | 03:11 PM
JettaRed's Avatar
Veteran: Army
Direct sun will NOT damage the roof. That's just ignorant!
When you say it stopped working, what do you mean? Power off and the glass is dark. It needs voltage to turn light. I think it needs something like 120V. There's a thread about it somewhere. But, definitely dark without power.
Power off (0V).
Power on (120V).
Old Jun 25, 2024 | 03:16 PM
JettaRed's Avatar
Veteran: Army
Read this thread...
SL/R231 Magic Sky Roof R231 - MBWorld.org Forums
Old Jun 25, 2024 | 03:21 PM
2017 SL 500
Yes Jetta, it’s dark
i’m still not convinced that it got damaged by the sun, thats just weird
Old Jun 25, 2024 | 03:24 PM
JettaRed's Avatar
Veteran: Army
While you are waiting on a price, check this. They ain't cheap. You most certainly want a second opinion. Since the default condition is dark, if yours is light and won't turn off, pull the fuse.
Old Jun 25, 2024 | 03:26 PM
JettaRed's Avatar
Veteran: Army
Those prices are just for the glass roof #2. An entire roof (#1) would probably total your car.
Top & Components for 2017 Mercedes-Benz SL 550 | Mercedes-Benz USA Parts (mbusa.com)
Old Jun 25, 2024 | 03:29 PM
2017 SL 500
Thank you for your help and time to post,
i thought it would be the fuse, but i saw him pulled it and ran the test, took the top trim and checked the module for electrical activity, but none of these were having any issues thats why he said most likely its the glass panel itself.
But you are right, i need to get a second opinion
Old Jun 25, 2024 | 03:35 PM
JettaRed's Avatar
Veteran: Army
So, is the glass dark or clear?
EDIT: Sorry, I saw you answered.
So, it's dark, meaning no power. At least you won't bake as quickly in the sun. Since the roof needs 120V to turn clear, that's where I would start looking. Do you have a scan tool for Mercedes? Did you read through the other post that I linked?
Old Jun 25, 2024 | 03:36 PM
2017 SL 500
Dark, won’t turn to clear when pressing the button
Old Jun 25, 2024 | 03:42 PM
JettaRed's Avatar
Veteran: Army
Just for reference, here's the control module.
Old Jun 25, 2024 | 03:50 PM
JettaRed's Avatar
Veteran: Army
(We're out of sync a bit.)
I would get a scanner specific to Mercedes and scan for error codes. If you want remote diagnostic assistance along with XENTRY, look up @BenzNinja
A scanner will give you live data and indicate if the voltage changes when you press the button.
Honestly, $19,000+ for the part and who knows how much for labor, I'd live with it. I rarely, if ever, lighten mine.
Old Jun 25, 2024 | 04:00 PM
2017 SL 500
He used this scanner
and when pressing the button the voltage remains zero.
I’m thinking could it be a weak main battery ? Although he did reset it and nothing changed
But really im still thinking what might cause the glass panel to go out all of a sudden !!!
Old Jun 25, 2024 | 08:25 PM
JettaRed's Avatar
Veteran: Army
You can also actuate the roof with the scanner without touching the button.
Sudden failure? Who knows? But if the roof isn't getting ~120V, it will not get clear. Using XENTRY, there are tests that can be performed to identify the failure. If your guy isn't using XENTRY, then he hasn't done the tests. I will post some screen shots to show you what I mean.
Old Jun 25, 2024 | 08:36 PM
JettaRed's Avatar
Veteran: Army
These are the diagnostic steps that XENTRY performs. I'll just do the first three to give you an idea.
Old Jun 25, 2024 | 08:45 PM
JettaRed's Avatar
Veteran: Army
You can use this screen to view the actual values. This was done using the XENTRY simulator. When the Output voltage is ~0V, the roof is dark (off). When you push the button, the voltage should be ~120V.
To test if the buttons work, from Actuations you can use XENTRY to turn the roof on and off.
Old Jun 26, 2024 | 02:05 AM
2017 SL 500
I don’t remember these diagnostic tests appear on the guys screen, maybe his system was not updated or something, but definitely i’ll look for another shop and ask to do these tests and figure it out.
Thank you !
Old Jun 26, 2024 | 09:42 AM
2017 SL 500
i took it for a second opinion today
they guy said it's highly unlikely that the issue is from the glass panel itself unless it was damaged / broken (which in not in my case), and most of the issues with magic sky control he faced were either the wiring or the module itself.
So i'm probably gonna order a new module or off from ebay.
Old Jun 26, 2024 | 10:24 AM
JettaRed's Avatar
Veteran: Army
Glad you got a 2nd opinion. I'm sure the first guy wanted to sell you a $20,000 roof.
Looks like new controllers are about $550. You may want to make sure you can return it if it doesn't work.
Old Jun 26, 2024 | 10:26 AM
JettaRed's Avatar
Veteran: Army
Pretty sure this is a Mercedes dealership.
Old Jun 26, 2024 | 11:42 AM
2017 SL 500
I'll look them up and order one.
i forgot to mention that both times when they tested with XENTRY, the result was a message of : There is an open circuit.
and again i'm very grateful to you helping me figuring this out !
Old Jun 27, 2024 | 05:22 AM
2017 SL 500
I want to change the wiring also, just to prevent any future failure of the unit
Do you know the part number ?a
Old Jun 27, 2024 | 08:08 AM
JettaRed's Avatar
Veteran: Army
There are a bunch of wiring harnesses. It's not clear which would control the roof. But I would expect it to be very expensive, if you can find it. I would wait until there is a problem since taking the car apart to find it is additional work anyway.
I also discovered new roofs to be unavailable from my local Mercedes dealerships. But I did find this: Folding Roof, Front MERCEDES-BENZ 23179016409040. Buy online at Cars245
Old Jul 16, 2024 | 02:39 AM
2017 SL 500
DIY replacing control module
I will be receiving the new control module today and i was wondering is it easy to replace it myself or do i have to go to the shop ?
Old Jul 17, 2024 | 12:08 PM
2017 SL 500
UPDATE : i replaced the control module with the new one, unfortunately it did not solve the problem
all wiring were checked and battery reset was done.
I don't know what to do, it seems like the glass roof panel is the issue here ?
