SL/R231: R231 Dreaded trunk
Trunk opens completely fine. Then i press button to lower it. It will lower and that's it. It will not even attempt to latch. I try to manually lower it - same story. It only attempts to latch if i use the button on the front driver door because it seems to slam the trunk harder, but then it will pull then pop up then pull then pop up a few times until it gives up. If i run out and hold the trunk down with my hands - it'll finally close sometimes. Not always. Takes a few tries. I got used latch replacement off eBay. It worked only the first time. Then started doing same thing. I thought its defective. Got that one replaced and same story with another one. Once installed. First press would lock perfectly. Open. Close - back to same ****. So mine and 2 others are doing same thing. I also noticed that the small metal latch inside the actuator would close and lock in place before it goes into my car and after i install it in my trunk it will attempt to close fully the first time around and then afterwards if i move that piece manually with finger to latch it will not lock in. In all cars if you move the metal in actuator it would lock in place. But in mine it stops locking.
That's probably not your problem given the weather. A couple of suggestions:
1. Check the adjustment of the striker that the latch hooks onto. That can be adjusted up and down. If you can hear the latch cycle normally but it doesn't close then this might be the problem.
2. There may be a broken wire in the cable that goes to the latch. Check the cable at the point where it bends with trunk lid movement. A couple of those wires connect to the micro switches, which tell the computer latch position.
R231 550 Replaced latch, trunk struts and a whole buch of ****! Turned out to be this
