SL/R231: STARTUP_Rattle R231
Old Dec 13, 2024 | 03:06 AM
elblanco's Avatar
SL 63 SL400
Question STARTUP_Rattle R231
Greetings fellow aficionados. I recently started to hear little funk at startup. Doesn't sound normal, and I thought I would field the query for an extra set of trained ears before I pull the stealership trigger.
Audio file attached, rattle occurs during first 4 seconds of cold startup
75K miles regular oil changes and tuneups.
Thanks for checking out my thread.
Cheers
Madison
File Type: mp3
Old Dec 14, 2024 | 05:45 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Sounds like chain tensioners and check valves.
Theres the TSB on the issue:
https://www.tsbsearch.com/Mercedes-B...05-10-P-056435
If it’s the tensioners it is a somewhat easy fix
see these other threads:
https://mbworld.org/forums/sl-class-...2013-sl63.html
M276 thread, but they have same issue:
https://mbworld.org/forums/sl-class-...tallation.html
Good Luck!
Old Dec 16, 2024 | 12:43 AM
elblanco's Avatar
SL 63 SL400
Thank You! I will have the dealer look at the above mentioned, and will post an update.
