SL/R231: Rough shift when cold
Years ago, and I mean YEARS, I had a 1978 Cutlass Supreme and one zero degree morning in NY states, the car was very slow to shift when first started. Never happened again, so I don't know what to say.
Do you start off in E or S mode? It shouldn't matter since even in E mode the tranny will start in 1st gear until warmed up.
I don’t remember, but what’s your mileage? 30k? Doubt it’s transmission itself.
Sometimes if the transmission is slightly under filled it can exhibit behavior like this in cold weather.
These transmission fluid levels are set using temperatures. It’s easy to get them “close”, but just slightly off.
Sometimes adding just a bit of fluid can solve this. It’s not something I would do Willie Nilly, but you may want to mention that you’re having cold weather shift issues to the place that did your transmission service. Give them a call.
Good Luck
Good Luck
Thanks. Dealer is 60 miles away but I'll see what they say.
Is it definitely true that the tranny starts in first gear when cold even in E mode when the dash indicator says 2?
https://mbworld.org/forums/glc-class...m_content=post
1. Ambient temps were 30 degrees F. Car was parked in a non-heated garage.
2. Started the car and let it run for about 30 seconds.
3. Backed out of the garage into the alley behind our home about 100 feet.
4. Car in E mode. Dash showed second gear.
5. Very slow acceleration, after only about 2 seconds felt what I feel was a shift from 1st to 2nd gear. Dash still said second gear.
6. After approaching the street I stopped and started out again. Same thing, what felt like a shift from 1st to 2nd gear.
7. I drove around for about 15 minutes, making several stops with the same result.
8. Went onto a highway and drove at 45 - 55 mph for another 10 minutes.
9. Made several stops in E mode and did NOT feel any shift until it went from 2nd to 3rd gear.
10. Changed to Sport mode to start in 1st gear. Tranny holds in first much longer than it did when starting in E mode with a cold engine.
I am convinced that the transmission does indeed start in 1st gear when cold and in E mode.
Would welcome others to chime in.
🎵BabyShark, do do do do do do BabyShark, do do do do do do BabyShark, do do do do do do BabyShark...🎵
Added:
Just returned from a 30 mile ride to get hot fudge sundaes. Transmission performed perfectly. Let the car idle in driveway until idle speed dropped below 1k. Drove off slowly down our alley. First couple of shifts were a little rough but after about 5 minutes all shifts were smooth and uneventful. All is well.
Added:
Sounds 100% normal for a cold car. Hope the sundaes were tasty!
