SL/R231: Massage function inop
Old Dec 16, 2025 | 02:18 AM
Blumey's Avatar
2013 SL 63 AMG and 2003 ML 500
Indie diagnosed leaking line from pump to seats.I agree after testing pump and electrical. Replacement cost is high, and as I will have my car long term, I don't want to have to do it again. And again. Is there any solution besides the factory part or making it myself? Appreciate any feedback from those that have been here.
Old Dec 16, 2025 | 06:58 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
There are many threads on this forum dealing with leaking seats... here's a few, as well as a link to parts that one member found useful. Some of the links also contain functional and wiring diagrams.
Good luck!
https://mbworld.org/forums/c219/5723...look-here.html
https://mbworld.org/forums/sl-class-...t-inflate.html
https://mbworld.org/forums/sl-class-...ml#post9191698
https://mbworld.org/forums/sl-class-...lfunction.html
Amazon Amazon
Old Dec 16, 2025 | 07:19 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Had the issue on my 2014 SL. In my case the leaks were the hose fittings at the pump. I found it by slightly lifting the pump out of the foam cradle. I heard hissing noises as I did that. There's a small o-ring in each of those fittings. I treated the o-rings with silicone grease. Haven't had a problem since. I posted my findings on these forums, but I don't have a link to it at the moment.
You can have leaks in the bladders within the seats, at the hose fittings, and the plastic reservoir has been known to crack. It seems very unlikely that anywhere else along the hose is going to develop a leak.
