SL/R231: Strut Replacement - When and the cost?
Old Dec 23, 2025 | 04:06 PM
westy1595's Avatar
2026 GLE53 AMG
I have a 2014 SL550 with about 15K miles. It rides rougher than I'd expect and just wonder if the struts.. may need replacement.
What's the groups experience with this and typical costs, etc.
Old Dec 24, 2025 | 07:36 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
I assume no ABC? ABC provides for a smoother ride.
What size wheels? It's best to stay with 18 in wheels if no ABC.
Are the tires run flats or not? Run flats have a much harsher ride than regular tires.
Old Dec 24, 2025 | 12:13 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
With only 15k miles your struts/shocks should be OK. Any sign of leaks?
Check your tire pressures. As said, runflats are harsher. I switched to goflats.
Old Dec 25, 2025 | 12:05 PM
westy1595's Avatar
2026 GLE53 AMG
Happy Holidays! I have the 19" AMG Wheels with non-run-flat tires. The Continentals are not my favorites, but are essentially brand new with 7K miles on them.
I'm scheduled for my 12 comprehensive maintenance next week (heavy sigh) so I'll consult with my tech at that time. I also agree, the tire pressures make a huge difference.
Old Dec 25, 2025 | 12:51 PM
jmattioni's Avatar
Happy Holidays!
Concerning tire pressure - use the numbers in the gas filler door and not the ones inside the driver's door, which are maximums.
Old Dec 27, 2025 | 09:52 AM
GTIBlack's Avatar
Mercedes SL R231
Is the car new to you?
Did it always ride “rough” or is this a new development?
If there is a previous owner, could they have replaced the struts/shocks with stiffer ones for a “sportier” ride? The OE shocks and struts are Bilstein B4 DampTronic.
Failed struts/shocks usually give a bouncy ride, not a stiffer one. Also, you should be able to bounce each corner of the car to check the condition of the struts/shocks. There’s a very good chance that you are just expecting something more comfortable. I find the DampTronic struts very comfortable, but just not ABC level.
Old Dec 27, 2025 | 09:55 AM
GTIBlack's Avatar
Mercedes SL R231
Take a look at your struts and shocks. Are they black or yellow? B4 is black and B6 is yellow. B6 is stiffer than B4.
