SL-Class (R232) Discussion on the 2022 R232
SL/R232: Loose steering, tire pressure?
Old Feb 8, 2025 | 10:13 PM
trikoid's Avatar
09CLK550Cab 61k miles
I just bought a CPO 2022 SL63 today, and I found the steering to be a bit loose, as it tracked the road a bit too much, and had 1/8-1/4” of play with no impact to steering.
The tires were around 32 psi. Would higher work better? What pressure do you all use?
Has anyone found a way to tighten the steering?
PS other than that, wow I love this car
Old Feb 9, 2025 | 12:48 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
My tires were initially at 32psi or so. But when the summer ended, I got a tire pressure message on the dash display. I had them topped off at top of spec, around 45psi. I didn’t see any difference in ride or performance yet.
As for the steering wheel. I don’t have any play in it. It seems to me that the play you are noticing is not normal.
Old Feb 9, 2025 | 05:00 PM
trikoid's Avatar
Thanks for confirming my worry, That's what I assumed. I remember sitting in a different one when the power was off, and moving the steering wheel either direction required real work. It was tight and springy.
In this car, I can put the _slightest_ pressure in either direction and I get 1/8" of travel at the perimeter.
