SL-Class (R232) Discussion on the 2022 R232
SL/R232: 0dd Seat back adjustment when positioning
Old May 9, 2026 | 06:14 PM
Neptune36's Avatar
2020 S560, S 580, SL550, E450 Cab
New to me SL55. Trying to get more leg room but as I position back the seat to where I get desired leg room, the seat back leans forward. So now I have leg room but now I'm leaning forward. I'm thinking maybe some code decision to ensure rear "seat" room exists if driver moves his seat back too far?? I set the auto seat positioning to 7'3" and helps a little but not enough. Is there a defeat of this position conflict? Keep seat back comfortably reclined while maxing out rear postion?
Old May 10, 2026 | 07:17 AM
jazporsche's Avatar
2023 AMG SL55 Performance, 2023 Audi Q8 Prestige
I’ve noticed this as well. I believe there is a programmed limit so the seat does not crush the wind screen when installed. After adjusting the leg room (and seat back automatically comes forward) I can get a little more room by tilting the seat back, back manually.
Old May 10, 2026 | 09:30 AM
Neptune36's Avatar
Interesting rational and makes sense. Yes I've tried the manual seatback setting to tilt back but it causes the seat to skoot forward as the back tilts. Meaning the back still retains whatever safe distance its programmed for then back to less leg room, Seems a "coder" could come up with a work around.
Old May 10, 2026 | 02:30 PM
Wolfman's Avatar
Super Moderator
This behavior is standard for several SL generations. This includes space for the comfort exit/entry feature where the seat moves back before exiting the car. When the seat is moved back too far, the feature is also not working. They simply have a max backward movement; after that the backrest goes more vertical before stopping to still support the safety systems to work...
Old May 12, 2026 | 12:46 AM
PNBLWZD's Avatar
2016 S550
I noticed this seat positioning behavior as well when trying on an SL for size in the showroom. S class sedans do this also, albeit to a much lesser degree
Old May 12, 2026 | 07:23 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
My EQS SUV does the same thing when I fold the rear seats down.
