SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Front seal replacement
Old Jun 29, 2007 | 02:14 PM
jjpj0's Avatar
76 450 SLC
Smile Front seal replacement
Hi All - new member here. Have a 76 450 SLC (117k and a daily driver) Front seal has started to leak. Not a lot of room to work down there - how hard is it to change the seal out - I don't have a hoist.
Any tips would be great. John.
Old Jul 8, 2007 | 12:58 PM
RoadkingHI's Avatar
05 SLK 350, 97 S420, 92 Jeep, 04 Kia, 28 Ford Tudor, 51 Ford F3, 01 Harley, 03 Harley
Surprised no one has commented on this. Not much info in this forum on technical.
I have not replaced seals on this type, however with other small, tightly packed cars the engine needed to be pulled.
If it is a slight leak then you could live with it, even though it is frustrating, until the time comes when you had enough and the pull the engine.
Old Jul 17, 2007 | 05:16 PM
jjpj0's Avatar
76 450 SLC
Thanks for the heads up - I kind of suspected it was a motor out deal. Just back from a trip from Tucson (home) to Durango CO and back - curiously the seal has stopped leaking.
Cheers John.
