SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 560SL brake pads - sensors
Old Nov 19, 2009 | 01:57 PM
slik560's Avatar
SOLD both: 1987 560SL 2003 ML320
I am planning a winter project to replace the pads on my 560SL with some Porterfield or Wagner pads to cut down on the dang DUST.
The existing pads don't really need replacing yet, so could I get by without replacing the sensors? I have not dug deep enough to see just how hard a DIY project this would be. I have a decent price from a really great shop for pads/sensors, but if I could save 50%...I might do it myself.
Any feedback is appreciated!!
Old May 7, 2010 | 09:06 AM
ironman21's Avatar
1987 Mercedes 560 SL
The pads and sensors are very easy to replace did my 560sl, should take about half hour each side or less 2 bolts hold the calipers, their are 2 pins that hold the pads in place along with a flat spring, tap these pins out and compress the caliper pistons (yours should have a dual caliper piston set up) using a caliper press (sears for about $10 bucks) install new pads, spring and pins attach to car.…………….. done.
No need to open brake fluid valve.
