SL/R107: timing question
Now for a much needed statement. For those of you out there that find yourselves in the same situation that i was, think long and hard before you attempt to pull the heads and timing chain cover. It is turely the worst engine i have ever had the experience of working on. I build custom rotary engines, hot rod engines, and even rebuild antique engines going all the way back to the 30's, and this monster has thus far beat out every engine i ever worked on by being the worst. The problem is that with most car makers engines you can see something and ask the question why was something done a certain way and actually come to some logical conclusion. This engine is about 50% that way, and the other 50% making no sense at all. It leaves you scratching your head and trying to convince yourself that this is still a mercedes engine.
