SL/R107: 86 560sl taillight power
560sl driver side taillight is not getting any power, what would be the best way to approach this? I have was told that the problem is behind the fuse box? Will I need to buy any particular parts?
82 380SL 96 SL500
I'm assuming you've checked your fuses?
Have you used a voltmeter to check for lack of power at the light both accross the bulb and from the hot terminal to a chassis ground?
A bad power connection or a bad ground are number one on my list, both at or in the immediate vicinity of the tail light.
Behind the fuse box is pretty low on my list.
