SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 1987 560SL Possible Electrical Issue?
Old Nov 21, 2010 | 01:31 PM
Hawkeye 1987's Avatar
1987 560 SL
Question 1987 560SL Possible Electrical Issue?
Hi....I've enjoyed this Mercedes for the last 3 years...No problems.
I have a 1987 560SL. I took it for a ride this spring and the temperature gauge started to creep up and got to overheating. After extensive replacement of parts in the cooling system and no luck getting the gauge to respond...I finally took it to a guy who chases this kind of problem. The problem being at this point is that when the blinker goes on, all the gauges respond in a back & forth and up and down movement and an increase in the temperature gauge when the blinker is on or not....The cooling system is fine (He took a laser and found it NOT to be overheating). He took out the instrument cluster....got it tested ....It's OK. He chased and found ground wires....replaced some and sanded the rest....Still nothing! Is there anyone out there who might have an insight as to what is going on? A specific ground or harness wire?....We seem to be at a dead end....He has had an older Mercedes Tech come down and try to help....Still to no avail!
I'm up in Massachusetts and will end up putting this car back in the garage for the winter...I'm hoping to get the problem solved before spring!! Hawkeye 1987
Last edited by Hawkeye 1987; Nov 21, 2010 at 01:33 PM. Reason: I want the model in the title.
Old Nov 21, 2010 | 04:17 PM
abiby's Avatar
82 380SL 96 SL500
Although your tech found, tightened and cleaned ground wires and connections, there is a ground connection on the Printed circuit board of the cluster known for breaking. If this is the case, you can resolder the traces on the board or easier, add another wire from the cluster to a good ground point.
If he did check this particular ground circuit.... never mind.
Old Nov 23, 2010 | 12:39 AM
1987 560 SL
Smile 560 SL Issue....
Alan....Thanx for the post. I've relayed the info to my mechanic....Hopefully we'll get somewhere soon.
Thanx,
Rich
Old Nov 24, 2010 | 12:06 AM
1987 560 SL
Smile Electrical Issue...
Had my mech take a magnifying glass look.....There was the crack right in the printed circuit board.....THANK YOU ALAN!!!!!
Old Nov 29, 2010 | 04:16 PM
slik560's Avatar
SOLD both: 1987 560SL 2003 ML320
Mercy...one more idiosyncrasy for the 107 list! Thanks for sharing the information. I've flagged it for future reference...just in case!
