SL/R107: Installing aftermarket radio in 1980 450 SL
1. Where does the long gray cable attached to the radio run to? This connection does not unplug directly from the radio, but I am assuming it goes to the amplifier.
2. Besides for the gray cable, there is only a brown wire with a ring terminal (ground), and one power cable, which seems like its a switched power source. Where is the best/safest spot to tap constant power off of and is the switched power source already there adequate? I have already ran new speaker wire to the fronts.
3. Is there any way to retain the motorized antenna that is controlled by the button on the dash or at least have it always in the up position?
Ps-what I have shared is my experience on a 1976 4.5l roadster. The platform didn't change thru the '80 you're dealing with, I don't believe.
