SL/R107: 380 Sl 1983 Instrument Cluster
Need some help to trouble shoot the instruments mainly Fuel Oil and temp needles flick when the indicators , or hazzard, are worse when at night when main beam or dip is used. The problem was intermittant but now its most of the time. I have removed Lights indicators and checked grounding and refitted. I now thinking I have to dive into the Dash Board oh what joy. Hopping you can help Charlie in Italy
82 380SL 96 SL500
I can pretty much assure you it's a grounding issue. There's a trace on the cluster PCB that has a history of breaking. If you run an additional ground wire from the cluster to a chassis ground (helps to put a quick connect in the wire) I believe you'll be good to go.
Here's a post with a pic.
http://www.benzworld.org/forums/r-c1...ml#post4664820
Grounding the instrument cluster
Abiby, got the extra grounding to Cluster I can do that, now tell me the best way to get to the cluster, I have done some repairs on centre consol cigar lighter not working heater controls etc, but never taken out the Instrument cluster, I can take the steering wheel off so take if from there Best Regards C
82 380SL 96 SL500
Go to post #2 of the thread I listed earlier for instructions on removal of the cluster. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
It would be a good opportunity to replace bulbs and do a little housekeeping while you're in there.
Instrument custer grounding
Alan, thanks I'm good to go now, the cluster link to the step by step photos is excellent better than a manual, good idea to do some spring cleaning as well while I have the cluster out. Many thanks will let you know the outcome. Charlie
380 SL instrument cluster grounding
Alan, hey presto, it worked as you said it would, took about 45 mins to sort out the new grounding identical to photo + i changes all the bulbs and did some general tidy up. the car is cleaned and polished back in the garge undercover. Many thanks for your insights Charlie
interior cover for rear shock 380sl
I am redoing the interior of this car and I am missing the plastic or rubber cover on the panel behing the seat to access the rear shock... I can't find the part listed anywhere.....does anyone knowthe part# or where to get it ???????
2000 miles across europe
Alan
Just got back from my annual "Boy Run" Italy, Swiss, France, Germany and UK plus return back to Italy all in 48hours ( 24hrs rest for a few days then return) lots of driving 3500Kms about 2000miles not a peep from the car and the instruments all worked perfectly so I think the road test was a pass, many thank for the help. Oh yes, the odometer recorded about half the milage so next job is to source the gears and replace.....Charlie
