SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 560SL center armrest
Old Sep 10, 2014 | 04:13 PM
alfista164's Avatar
2007 CLK63
Fellow members
My recently acquired pristine '89 560SL has a collapsed center armrest. Although it pivots up/down just fine, when in the down position it does not stop in horizontal, but ends-up resting against the console in a down-sloping fashion. I am trying to find out how it would normally stop horizontally. Is there a "stopping" mechanism on the seat? On the armrest?
Thank you in advance
Old Sep 15, 2014 | 10:38 AM
slik560's Avatar
SOLD both: 1987 560SL 2003 ML320
There is a bracket inside that is supposed to stop the unit when it is in an approximate level position. I do not know if this stop could be replaced or whether the entire mounting bracket assembly would need to be replaced. I would look it up on EPC-Net, but my subscription expired!! Good luck with this. Try Benzworld while you are at it.
Old Jun 28, 2015 | 11:13 AM
spsinha's Avatar
1994 E320 Coupe, 1979 500SLC, 2005 E55 - Sold
Armrest
Any luck? I have the same problem
