SL/R107: 1974 Benz 450SL $7500
I have a 74 Benz 450SL Vert with both the hard top and soft top, original 49,850 miles.
Hard top is new, soft top could use a little reconditioning as it just sits in the compartment 24/7. Some weather stripping is new, the car had a complete tune up including points, plugs, wires, and all fluids. Front suspension is vitually new. Nearly no rust, you'd be hard pressed to fine any, the body is in great shape except the hood has some acorn dents. Paint is great. Original everything including bottle caps and the wheels are mint. Interior is all original and nearly mint but would need a dash painting as it's not cracked but the color of it isn't the same quality as it once was, and the center console would as well.
Car will need an A/C recharge as compressor and blowers work but it only comes out hot.
Will also need the ebrake cable tightened.
Great car. $7500 AS IS!
text 2014007471
