SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Fuel pump not pumping?
Old Apr 26, 2020 | 12:23 AM
sped01's Avatar
I purchased a 1976 450SL and knowing that it sat for some time I removed the fuel tank and had it cleaned. I replaced the fuel pump, filter and accumulator. After filling the tank with some gas I find it will not pump gas. The fuel pump shudders one time when the key is turned on and that's it. I want to run the pump to clear the fuel line but it does not pump.
Any ideas?
TIA, Ed
Old Apr 26, 2020 | 05:47 AM
optimusprime m1's Avatar
W124 260E
They only run a short time till engine starts ,if no start it switches off . ..If its been sitting i would check all the fuses clean and refit .
Old Apr 26, 2020 | 05:59 AM
W124 260E
Might be fuelpump relay see pcture . But first is to check the fuel pump fuse . Look at your fuse chart i can see number 14 fuse but your model 450SLfuel pump .
Old Apr 26, 2020 | 03:16 PM
TheShadow619's Avatar
1981 380SL
Could be the fuel line is plugged hard. If the fuel can't flow, it will stop the pump. Disconnect both ends of the fuel line and try blowing compressed air through it. Start out with low pressure.
