SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Rescued a 560 now have a question
Old May 1, 2020 | 01:54 PM
White Spyder's Avatar
2003 R230
I am new to the R107 (own a R 230) and found a ‘88 that has been sitting for some time. Got the car running and now have a question about operation. When moving the gear selector from park to reverse the transmission shifts smoothly bu after a moment the rear of the car rises as torque is transferred. No clunks or clangs and the rear diff doesn’t rock or move. The drive shaft turns slightly when the shift is made and a moment later rotates another 1/4turn causing the rear to rise.
When going from neutral to drive the car sits down a bit in the rear but not as much. Is this normal for the R107 or is there an issue with the differential.
Old May 2, 2020 | 07:30 PM
steve sl550's Avatar
1986 560SL, 2017 E300, 2018 Sl550, 2020 E350
Just back from a ride in our 1986 560Sl with 32K original miles (we are original owners).
I too noticed a difference like you mentioned when shifting into reverse when originally moved out of the garage.
I idle @ 800 RPM in either drive or neutral if that helps.
I too see the attitude you mention in going to drive.
Old Jun 21, 2020 | 10:53 PM
cdk4219's Avatar
95 SL600
Yes the rear trailing arm suspension leads to this squat and lift. Not the best engineering design but it works.
