SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Oil and filter
Old Sep 20, 2020 | 01:39 AM
TheShadow619's Avatar
1981 380SL
Oil and filter
I'm sure it's been addressed before, but what oil filter brand and oil viscosity do you use? I like to synthetic. I'm thinking 5w-30 Mobil1 synthetic. I have a 1981 380SL.
Old Sep 21, 2020 | 03:40 PM
AlterSchinken's Avatar
1985 380SL
You should not use a modern "fuel saving" motor oil. These do not have the necessary wear additives that older engine designs needed from new. I use Mobil 1 15W-50, this is formulated with high zinc levels for use in engines such as the old Mercedes M116/117 engines. I am in Georgia so the viscosity suites the climate. I think Amsoil makes such oils in various viscosty ranges. Look for oils with higher ZDDP levels. Personally I use the Mann filter but I think for the miles these cars are driven any quality filter is ok. The bypass valve is not part of the filter so this isnt as much of a potential issue like most cars.
Old Sep 21, 2020 | 04:36 PM
chilton450sl's Avatar
1977 Mercedes Benz 450SL
First, blessings to you for the care of a classic Mercedes R107 roadster. You may stir controversy; one poster threatens to sock for talk of synthetic oil! I defer to my mechanics-elders and used 15W-40 conventional oil as stated in the MB handbook, MB service manual, and used with other antique engines. I considered Liqui-Moly 15W-40, but simply went with FS brand, that's what we use on the farm. Even Joe's old '53 Corvette runs good on the stuff, and many old Mercedes. The mechanics-elders told stories of synthetic oils causing gasket leaks. And my 450SL runs great on conventional 15W-40 - really purrs over 100mph. I used a Mann oil filter - OEM Germany, won a youtube test, and good deal online with washers/seal. Also popped in the recommended Mann air filter, Bosch fuel filter, Bosch distributor cap/rotor, Bosch spark plugs, and Karlyn wire-set. The fuel filter was exposed to weather below so the holder bolt rusted; had to drill it out and replace the bolt. Really needed a new fuel filter; there was black gunk dripping out! Using Seafoam to clean out the lines of gunk. What a difference!
Old Sep 30, 2020 | 09:48 AM
turbo 50's Avatar
500SL 450 SL 230 SL E320
Use Mann brand filter.
In an old Mercedes do not use synthetic or you will have oil leaks thru the seals.
Use Castrol non synthetic 20W-50
