SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: idle problems
Old Sep 15, 2004 | 08:00 PM
g. lapiene's Avatar
idle problems
my 380sl starts and illes at 1000rpm in gear with the brake on it drops to 750rpm when you go to neutral rpm jumps to 1500 and takes several seconds before it drops back to 1000 my mechanic says leave it alone but if you go from reverse to drive in as you normally would it will spin the tires anyone have any ideas?
Old Oct 27, 2004 | 07:45 PM
Dave Childers's Avatar
Idle Problems
It sounds to me like a vaccuum issue not allowing the engine to adjust quick enough to the shift.
Old Nov 7, 2004 | 03:50 PM
m117968's Avatar
96 S600 Euro, 91 560 SEC, 88 300TE, 87 560SEL, 86 560SL, 80 280SE, 64 Austin Healey 3000MIII
Could be vacuum or air idle valve or idle control unit. Not sure what your mechanic is thinking.. rpm's like that are going to beat your driveline to pieces over time, as well as put excess strain on the torque converter.
Start by checking the vacuum, I'm wagering you should have about 15 inches steady..
Check it off the back of the intake manifold, passengers side.
Jonathan
