SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Fuelpump
Old Sep 16, 2023 | 03:42 PM
kurt500sec's Avatar
r107 sl 450
Fuelpump
Hello
I need help with a R107sl 450 sl 1972 us model.
The fuel pump (new) does not run when I turn the ignition on
It runs fine while the starter is running.
When the engine starts, the fuel pump stops again, the pressure disappears and the engine dies.
Relay for the fuel pump and main relay are new.
Anyone have a suggestion as to what the error is or what trigger the fuel pump relay when engine is running?
Best regards, Kurt
Old Sep 17, 2023 | 05:14 AM
ygmn's Avatar
2015 E400 Sedan
sounds like it is wired wrong.
Wired to start circuit not Run circuit so only gets power when in START position.
Old Sep 18, 2023 | 02:26 PM
AlterSchinken's Avatar
1985 380SL
Here is a troubleshooting guide, with wiring diagrams. Starting on page 9 the process is shown using only a multimeter.
File Type: pdf
