SL55/63/65/R230 AMG: Modified SL55 vs stock SL65 who would win ???
Anyway, how must one interpret this (false) statement about 65's, VMAX and performance package?
I have no idea why the comments were made the way they were. What I do know is that I personally know a couple of people that are in Germany that run their SL65's hard with the limit raised to 300 by AMG and none of them have overheating issues.
I do agree with Maff, the only time I see the needle move is at slow speed in heavy traffic.
Enjoy
I'm just passing on the info that was provided to me, and it makes sense to me. If its true or not...
I'm just wondering this, not to bash on Rob or anything, but It's just that regularly discussions on this forum are being cut short when someone argues "but Rob Allan told it, so there", while other clearly knowledgable people tell otherwise.
Car and Driver Mag, August 2005
Ironically, our acceleration results are slower than expected, even though the car meets the factory claims for 0-to-60 times. That may be due to the intense heat (over 90 degrees) at our desert test site, where repeated runs had the car's coolant gauge reaching the top of its scale, whereupon the engine computer cuts boost and probably retards ignition spark, too, for good measure. That slows the SL65 right down.
It did the same thing at the Streets of Willow, where we could record only one lap before an identical situation arose. One look under the hood suggests an explanation. There's a tightly packed cluster of hot plumbing under there, and engine-bay airflow is clearly not up to the task of scavenging it. Still, we can't think of anywhere you could use full power for long periods of time in this car in normal circumstances. Except maybe on the autobahn, where high-speed airflow would doubtless cure the problem.
Where the SL65 stood apart from the others was in the quiet, smooth way it goes about its business. The others get in your face. This one plays it cool.
The 65 ran with the GT even under conditions that were not to its advantage. Cooler weather may have given the 65 the top dog spot as far as top speeds and acceleration.
