SL55/63/65/R230 AMG: Real Paddle Shifter
I don't know if it's possible to upgrade your existing SL55 to paddle shifters, but why shouldnt it work? Maybe you have to exchange the complete steering wheel.
If you drive a racecar the ratio on the steering wheel is high, so you have a max of +- a half turn from side to side, wheels fully engaged, paddleshifters are ok, you have em right at hand where you want them.
If you drive a normal roadcar, and getting into trouble, lets say the rear end is drifting out, you have to turn the wheel fast to the same side as the car is drifting, this is when you get in trouble with the paddleshifters. You grab the wheel fast, move your hands fast, turn the wheel fast, and during this proces you hit the paddleshifter(s) with the result that now suddenly the gearbox starts changing gear as well.
If you try to get hold of the car, and you might even use the engines horsepower to try stabilize the drift, and the gearbox suddenly changes gear, you might loose the car, if you are not an experienced driver.
The shifters integrated in wheel, as today, are far better, in my opinion. It is unlikely that you hit them by accident, and they are never in the way.
I have heard that the 2007 SL will get steering column-mounted padddle shifters:
i would still take a stick though
