SL55/63/65/R230 AMG: has anyone removed the resonator
Old Mar 22, 2006 | 03:15 PM
eride's Avatar
996 supercharged C4cab widebody, x-5 (4.4), sl-55 kleeman, RR
just wondering how much louder better/worse is the sound without the resonator (straight pipe to muffler).
Old Mar 22, 2006 | 03:24 PM
SLcharger's Avatar
SL55AMG, ML420CDI, E320TCDI
There are 2 sets of resonators fitted on an SL55. I removed the front ones, and the sound is incredible. Deep throat bass and louder. It makes a real roar, and makes people turn heads. I can only recomend it.
Dont remove both sets, that will make the exhaust to noisy.
Provide some feedback, if you go for it.
Old Mar 22, 2006 | 03:42 PM
eride's Avatar
SLcharger, exactly, what i was thinking. seems a bit muted in stock form. calling Lucent today to have it done. thanks alot.
Old Mar 22, 2006 | 07:24 PM
JCortney's Avatar
2004 SL55
I removed the rear one (not the muffler). OUTSTANDING. Had my local muffler shop weld in a piece of SS, $200. In and out in an hour and now the car sounds like a car. Not loud, just a great growl.
Old Mar 22, 2006 | 07:30 PM
eride's Avatar
well, i'm assuming the 2 resonators are the same lengths as i haven't looked under the car. the car is getting worked on so i can't check. any help.
Old Mar 23, 2006 | 09:01 AM
Audioguy's Avatar
It would be interesting to see if there is a difference is how the exhuast sounds depending on which set of resonators you remove?!
SLcharger, and JCortney:
Would you gents consider taking a sound clip of your cars?
-Audio
Old Mar 23, 2006 | 03:20 PM
jonnyml500's Avatar
05' SL500 (Sold) - 01' S430 - 05' Yama R1- 02' ML500 (sold)
I removed my Muffler / sound clip attched
I took of my muffler and had a glass pipe installed. Here are some pic. and a sound clip with the mufflers off.
Its sounds awesomely great. did not remove resonators because worried about MAF error.
Sound clip with out muffler
http://media.putfile.com/SL-500-with-muffler-taken-off
Sound clip with glass pack
http://media.putfile.com/day87
Old Mar 23, 2006 | 03:26 PM
eride's Avatar
oh ****, the resonators are different sizes. are there any os sensors attached. this will become interesting.
Old Mar 23, 2006 | 03:59 PM
SLcharger's Avatar
The Lambda sensor is fitted right after the header, but before the front resonator. It is possible to cut the resonator off, and still use the bit of pipe with Lambda sensor. The front resonator is the smaller one.
Old Mar 23, 2006 | 04:38 PM
eride's Avatar
SL charger thanks for all the great input, since you have removed the larger one, is the resonance mild. i know it's hard to say as you have a larger down pipe and headers, changing everything, but a guestimated answer. that is if you don't mind.
Old Mar 24, 2006 | 02:42 AM
SLcharger's Avatar
Must correct, i removed the smaller ones. ( right after header )
Resonance, hmmm. There is a resonance at idle that you can feel in your body, if you stay in a garage or building. It is not overwelmingly, but it is noticeable.
You are right, since i have fitted the Kleemann headers as well, and at the same time as the resonator was removed, i dont know how mutch the headers are changing or contributing to this sound.
The guy´s at Kleemann say´s that their headers tend to make the sound more deep. If you stay with stock headers, you might not get the full benefit, by removing the resonator, but my guess is that it will still be a different and more appeling sound.
Old Mar 24, 2006 | 12:44 PM
JCortney's Avatar
2004 SL55
As I said, I removed the rear resonater. No resonance at all, none. I was expecting some but it just isn't there. The sound is so sweet that it's hard to believe that there weren't any other mods done.
Also, no sensors, no warning lights.
Hope this helps.
Old Mar 24, 2006 | 12:54 PM
eride's Avatar
Hope this helps.
it actually helps alot. that is the very answer i was hoping to hear. i will remove the rear since it is further away from the drivers cabin, should help muffle the resonance.
btw sl charger i am doing the kleeman upgrade k1 untill all fitment issues are resolved on the headers. and of corse i will be doing the LSD, as it can't hold down the power as is.
Old Mar 24, 2006 | 01:16 PM
JCortney's Avatar
2004 SL55
After you have it done, have someone drive the car up and down your street for you. You really can't appreciate the sound until you hear it from outside the cabin. Not to say it dosen't sound great inside, it's just the WOW factor outside is the ****.
Old Mar 25, 2006 | 01:35 AM
SJRAMROD's Avatar
Have any of you guys noticed a drop in power or......maybe an increase? It may sound like it's faster but, it really may not be. Just wondering what the effects on performance are with less back pressure.
Old Mar 25, 2006 | 01:42 AM
SLcharger's Avatar
Dont ecpect any noticeable chance in power. The power of those engines are restricted by the inlet at the S/C.
Old Mar 25, 2006 | 01:43 AM
SLcharger's Avatar
What fitment issues ?
You will love the LSD. Mutch better handling.
Old Mar 26, 2006 | 09:20 AM
JCortney's Avatar
2004 SL55
I honestly don't feel any difference either way.
Old Mar 27, 2006 | 02:29 PM
eride's Avatar
the word is the fitment of the headers is shaky, but then most headers are.
Old Mar 27, 2006 | 08:22 PM
newton22's Avatar
BMW E39
The resonators are placed a little after the headers. You can remove these and run straight, x, or y pipe etc.
The cats (catalytic converters) are placed before the mufflers. Don't remove these unless you're replacing them with an aftermarket setup. I believe this is where the O2 is too.
The mufflers of course are at the very end. Don't remove these either unless you are replacing them.
Hope that clears it up a bit.
Old Mar 30, 2006 | 08:50 PM
eride's Avatar
well i got the car back from Lucent Motors (the bomb). the Kleeman K1 is very torquey especially down low. a little twitchy but nice, unfortunately they did not have the LSD yet so i'm still waiting as the car absolutly needs it and i don't know why it doesn't have it from the get go. and today i removed the resonator, which by the way is right before the muffler, not after the headers or any of the photo's shown above those photos are the cats. there is only one resonator on the car, besides the muffler itself. the sound is dramatically louder/ throatier. it really wakes the car up, but not sure if it suits the car as it is a cruiser. so if any of you are planing on doing it, it is significantly louder, but not that much that it creates harsh cabin drone/resonance.
so the K1 is a thumbs up
LSD is a must
removing the resonator is loud
Old Mar 30, 2006 | 08:59 PM
eride's Avatar
not to be removed, these red squares are all the cats, not the resonator.
Old Mar 31, 2006 | 08:56 AM
SLcharger's Avatar
There we are again.
The complexity off language sometimes leeds to missunderstandings. When this tread was started i got the impression that you people call a Cat , a resonator, and wise versa.
Anyway, since this is now cleared, i moved the front cat´s. The rest of the story is still the same.
